91camaro_rs Member
Posted: Thu Oct 04, 2012 3:59 pm Post subject: 9bolt questions |
so my friend sold me a 9bolt and said it had 3.73 gears, and it ends up its a 3.23....so i wasnt very happy about that. so i have a 3.08 posi drum rear end now, is it worth the trouble to swap to the disc 3.23 9bolt even though i wanted 3.73's and will a 3.23 even make a difference?? _________________
jchaussee Member
Posted: Thu Oct 04, 2012 5:59 pm Post subject: |
| Are 3.23 posi.? |
91camaro_rs Member
Posted: Thu Oct 04, 2012 6:10 pm Post subject: |
Rear end i have now is a 10 bolt 3.08 drum posi. The one i just bought is a 3.23 9 bolt disc posi with staggered iron calipers . Is it worth the swap or should i wait for 3.73s _________________
Posted: Thu Oct 04, 2012 6:18 pm Post subject: |
If it's a 9-bolt then it's a 3.27. Still a decent upgrade I think. 3.27 is a great driver gear. 3.73 is a little high, especially with a 700R4 IMHO. _________________ 84 Camaro Z28 - LS1/T56
jchaussee Member
Posted: Thu Oct 04, 2012 6:23 pm Post subject: |
| Worth swap then.funner gears AMD disc |
jchaussee Member
Posted: Thu Oct 04, 2012 6:26 pm Post subject: |
| But if you don't want to swap, I'd be interested in taking it off your hands |
Posted: Thu Oct 04, 2012 6:29 pm Post subject: |
3.73 is perfect for stock trans ratios in these cars.
3.23/3.27 is no slouch. 3.08 is terrible.
I'd definitely swap it. It's stronger, better, and has disc brakes.
Only takes an hour! _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Thu Oct 04, 2012 6:59 pm Post subject: |
Ok ill keep it and swap it. So now here are more questions. Which ebrake cables do i need and which brake lines do i need
Also what is the website for new speedo gears i needed to change it when i did the 3.23 peg leg to 3.08 posi so Im gonna need another for going to 3.27 _________________
Posted: Thu Oct 04, 2012 7:03 pm Post subject: |
You shouldn't have to change brake lines. The lines native to the brakes/rear have a single T connection. Soft line from Chassis to Tee should be the same for you.
E-Brake cables again are brake specific. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Thu Oct 04, 2012 7:15 pm Post subject: |
There are no brake lines from callers to the tee. It didn't come with em. and i have no idea what vehicle to use when i look up parts for it. I have no clue what got this rear end _________________
Posted: Thu Oct 04, 2012 7:17 pm Post subject: |
WTF? Who sells a whole rear with brakes, but no brake lines?
You have to fabricate the brake hard lines then. Yours wont work, but you should be able to use the soft line tee. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Thu Oct 04, 2012 7:22 pm Post subject: |
Well that's great....good thing i work at oreillys now and can get discounts. I guess i need some long lengths of brake line and a tube bender _________________
Posted: Thu Oct 04, 2012 7:23 pm Post subject: |
| Twilightoptics wrote: | | 3.73 is perfect for stock trans ratios in these cars. |
3.73 + 3.08 first gear in the 700R4 is dumb. I ran it for awhile. 3.27 is fine for that transmission.
| Twilightoptics wrote: | | WTF? Who sells a whole rear with brakes, but no brake lines? |
Harbor kids.
I would hit the yards before I tried to build the lines. They have a tee fitting and one side has a softline and connector.
For a parts reference for brakes and whatnot just tell them you have an '86 IROC or Trans Am with rear disks. However, you will not find parts for the axle itself on the shelf anywhere. That stuff comes from junkyards or Australia.
You will need a prop valve, either aftermarket or the factory shuttle-thingy. |
Posted: Thu Oct 04, 2012 7:24 pm Post subject: |
| 91camaro_rs wrote: | | Well that's great....good thing i work at oreillys now and can get discounts. I guess i need some long lengths of brake line and a tube bender |
:nods:
And a double flaring tool. _________________ A redline a day keeps the carbon away! |
Posted: Thu Oct 04, 2012 7:30 pm Post subject: |
| Twilightoptics wrote: | 3.73 is perfect for stock trans ratios in these cars.
3.23/3.27 is no slouch. 3.08 is terrible. |
I've had all three in my 89. 3.08 was a great highway gear, but nothing more. 3.23 was a significant improvement and the current 3.73 is by far the best of the three. Gas mileage goes down with each numerically higher gear ratio... _________________ 92 Camaro
91camaro_rs Member
Posted: Thu Oct 04, 2012 7:36 pm Post subject: |
I just need to know what car its from so i can lookup brake rotors pads and brake cables _________________
Posted: Thu Oct 04, 2012 7:44 pm Post subject: |
| aaron_sK wrote: | | For a parts reference for brakes and whatnot just tell them you have an '86 IROC or Trans Am with rear disks. However, you will not find parts for the axle itself on the shelf anywhere. That stuff comes from junkyards or Australia. |
| 91camaro_rs wrote: | | I just need to know what car its from so i can lookup brake rotors pads and brake cables |
Posted: Thu Oct 04, 2012 7:54 pm Post subject: |
| If you can't find your flex lines from the calipers to the hard lines, they can be fabricated. I had a full set of three lines for my axle made at Belfair Hose, made them u while I waited - they're out by the Bremerton Airport. |
Posted: Thu Oct 04, 2012 8:37 pm Post subject: |
IIRC on my stock 10 bolt one of the caliper lines was hard lined. _________________ A redline a day keeps the carbon away! |
Posted: Thu Oct 04, 2012 8:43 pm Post subject: |
They may have done it that way on the ten as well. Last ten I had with disks went to the scrap yard where it belongs.
All I know is one side of my 9-bolt disk lines is soft with a junction block and a banjo fitting and the other is hardline right to the caliper.
The tee'd line coming from the chassis also changed threads over the years, so watch out for that.
