flea Member
Posted: Sun Oct 14, 2012 8:42 am Post subject: Fuse question |
Does anyone know right off hand which fuse the door locks are on?
What else might be going through that fuse.
Every time it rains a little my doors lock themselves and the battery runs itself completely dead. The idea I'm working with is that the lousy seal I have is letting water leak in, which is then working its way to the power lock connection inside the door, thus locking the door and essentially holding the button until the battery is dead. Short term solution is to pull the fuse and flip the sorry seal the bird. Or at least eliminate that possible cause. _________________ Killing mailboxes since 2009 |
flea Member
Posted: Sun Oct 14, 2012 11:03 am Post subject: |
Cool thanks. I'll look into that.
Tired of getting locked out.  _________________ Killing mailboxes since 2009 |
