Posted: Tue Jul 10, 2012 7:42 pm Post subject: Trans Am fender vents |
I've always liked how the Trans Am fender vents look, and since I'm replacing my fender I figure now would be the time to add them. I know that they are a separate piece but how are they attached? Speed nuts? Clips? Bolts? Adhesive? If anyone has a Trans am could someone measure the size of the hole in the fender? Pictures would be a huge help in this case too. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Tue Jul 10, 2012 8:52 pm Post subject: |
IIRC, the fender itself is stepped to hold the vents in place while the retention clips fasten them down.
You can kind of see it in this shot.
