Posted: Sun Jul 01, 2012 4:43 pm Post subject: Parts needed ASAP |
-right front fender
-front bumper cover
-1 chrome front 17x8.5 C5 Y2K wheel or 2 rear 18x9.5 Y2k wheels
-Trans Am fender vents _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sun Jul 01, 2012 4:59 pm Post subject: |
| Umm.. OUCH?! I hope this isnt your black car. |
Posted: Sun Jul 01, 2012 5:07 pm Post subject: |
| I have the spindle and tie rod in the shop if someone will be up this way, but I doubt it's worth shipping them from up here. |
Posted: Sun Jul 01, 2012 5:15 pm Post subject: |
| I was just in the vancouver pick n pull today. There were 4 third gens there. 3 were maro's but early ones. Might be a good spot for a fender and spindle though. |
Posted: Mon Jul 02, 2012 6:22 am Post subject: |
I'll have to check on what suspension pieces I have left. I gave Tony by big box with spindles and brakes. He might not have used them all, so he may still have the spindles and calipers, and rotors. I think he wanted the dust shield, and I made him take a box of parts I didn't need anymore.
I have a front bumper cover, I was saving it for when I paint my car, but if push comes to shove and you are not able to find another one, we can work something out. It is in really nice shape, that is why I am trying to hang on to it. |
Posted: Mon Jul 02, 2012 10:37 am Post subject: |
Well I did some digging around in the shop and I've found most of my spare parts from the '85 so I don't think I need a spindle anymore. I'm 99% sure that all 82-92 spindles are the same besides the 1LE spindles but I just want someone else to reassure me, is that correct? I also don't need the A-arm or brake caliper. I may see what my bodyshop can do as far as finding me a new fender and bumper cover. Almost all bumper covers I ever see are warped in some way. I'm kinda pissed about needing a strut though. They were only like 3 months old! _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Jul 02, 2012 5:21 pm Post subject: |
Are you sure you actually need a bumper cover? I see the hole, but that can probably be filled. It's pulled a bit out of shape but thats because its attached to a bent fender.
When my car was totalled because of being rear ended.. once I got the bumper cover loose it popped back into shape. I'm still using the same one today. |
Posted: Mon Jul 02, 2012 5:24 pm Post subject: |
My nosecone had a inch long tear in it when I painted my car. I remember using some kind of spot putty or plastic adhesive and gluing it back together and it is perfect to this day. I can't even tell where it was and I'm the one that fixed it.
I guess what Brandon and I are saying is if your nosecone is otherwise good it is probably easily repairable. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Jul 02, 2012 8:40 pm Post subject: |
If you change your mind about needing spindles, I have a pair that I got for free. They're yours if you want them. I don't recall what year they came from, though. _________________ 92 Camaro
BluFbdy Member
Posted: Thu Jul 05, 2012 6:41 pm Post subject: |
Ive got a fender for you if youre still in need its white if it matters i dont recall seeing any dings in it _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri Jul 06, 2012 8:43 am Post subject: |
| BluFbdy wrote: | | Ive got a fender for you if youre still in need its white if it matters i dont recall seeing any dings in it |
Can you double check on the condition? I want one that mint. Also, did it come off a GFX car? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
BluFbdy Member
Posted: Fri Jul 06, 2012 8:56 am Post subject: |
Yeah its off an 89 _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Sat Jul 07, 2012 9:24 am Post subject: |
I have all the factory brake components you could ever need or want. hit me up by phone 971-645-9359
-Tony |
Posted: Wed Jul 11, 2012 4:32 pm Post subject: |
I added a pair of Trans Am fender vents to the list. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
fiveoformula Member
Posted: Wed Jul 11, 2012 4:46 pm Post subject: |
| Did you get a fender yet? |
Posted: Thu Jul 12, 2012 12:49 pm Post subject: |
| fiveoformula wrote: | | Did you get a fender yet? |
Not yet. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
