new head questions
jchaussee
PostPosted: Wed Jan 25, 2012 6:15 pm    Post subject: new head questions Reply with quote
So I am getting new heads tomorrow on a trade from a guy. The are pro topline s rt or something. They have 167cc runners and are 1.94/76 . Curious if these would be an upgrade to my 882 smogers. These are sitting on my 327. Any info or advice would be appreciated.
PostPosted: Wed Jan 25, 2012 6:24 pm    Post subject: Reply with quote
Never heard of a Pro head with that small of an intake runner. Just 180cc or 200+.....
If it has vortec style chambers it will be an upgrade.
When the heads are off, measure the bore and stroke, make sure it's a 327.
jchaussee
PostPosted: Wed Jan 25, 2012 6:41 pm    Post subject: Reply with quote
I messed up. They are 1.94/67 not 76. And ya.. seems to be small runners but that's what the said they are when I ran numbers online.
PostPosted: Wed Jan 25, 2012 6:44 pm    Post subject: Reply with quote
You mean 1.94" intake and 1.5" exhaust valves?
jchaussee
PostPosted: Wed Jan 25, 2012 6:49 pm    Post subject: Reply with quote
194 intake
67cc combustion chamber.
And yes 1.50 exhaust
jchaussee
PostPosted: Wed Jan 25, 2012 7:00 pm    Post subject: Reply with quote
Also can I asumme I will have higher compression with these heads over the 882s
Ahh that's usually listed as:
Intake Runner CC/Chamber Size
Intake Valve/Exhaust Valve
IE 200cc/64cc 2.02/1.60
If it's 67 cc it's also been worked over and guessed at or measured for an actual 67.
jchaussee
PostPosted: Wed Jan 25, 2012 7:04 pm    Post subject: Reply with quote
My bad. I am all ass backwards. So here is info on heads. Pro toplone set
2236794167t
PostPosted: Wed Jan 25, 2012 7:36 pm    Post subject: Reply with quote
It's the first head on this page.
ProTopline Marine Torker
http://www.flatlanderracing.com/heads_promarinesb.html
EDIT: Same part number on these: Looks like they are old old old but maybe Vortec based chambers?
http://www.flatlanderracing.com/heads_protork.html
jchaussee
PostPosted: Wed Jan 25, 2012 7:41 pm    Post subject: Reply with quote
Sweet. They look like they will be an improvement
jchaussee
PostPosted: Wed Jan 25, 2012 11:44 pm    Post subject: Reply with quote
Another question I have is while heads are off, what other areas should be addressed. I have not done a head swap in over 10 years and when I did the last one I just bought a top end gasket kit from a machine shop. Is that the way to go?
jchaussee
PostPosted: Thu Jan 26, 2012 3:24 pm    Post subject: Reply with quote
So I got heads.. Need rods and rocker arms. I have no clue on how to buy them and make sure I get correct ones. Help.
jchaussee
PostPosted: Mon Jan 30, 2012 1:10 pm    Post subject: Reply with quote
Anyone??
jchaussee
PostPosted: Tue Jun 19, 2012 8:02 am    Post subject: Reply with quote
So I finally am getting ready to bring heads in to ha e them cleaned. I fin looked at them closer. They have double springs and trw guide plates. So I am hoping they have decent valves. Looks like somebody at least put a couple bucks into them.
PostPosted: Tue Jun 19, 2012 8:45 am    Post subject: Reply with quote
Pro heads come with that.
With guide plates you need hardened pushrods and non-self aligning rockers.
jchaussee
PostPosted: Tue Jun 19, 2012 9:02 am    Post subject: Reply with quote
Cool. Thanks for info. That narrows down my search
