Interior vinyle
jchaussee
PostPosted: Sat May 26, 2012 1:03 pm    Post subject: Interior vinyle Reply with quote
So I, have been covering a few of my interior plastics in vinlye. It,looks,pretty good. If I knew how to post pics I would. Gives it an updated look and will also quit down a,few rattles
BluFbdy
PostPosted: Sat May 26, 2012 1:47 pm    Post subject: Reply with quote
Make sure you use enough glue and a heat gun to form it properly I've seen too many times where people don't use enough glue and it comes undone or they have floppy corners I'd like to see this when you're done I want to do my door panels from scratch and cover them in vinyl
jchaussee
PostPosted: Sat May 26, 2012 1:51 pm    Post subject: Reply with quote
I used plenty o glue. It is a cenmet and the bonds get stronger with time. I going to do door panels, but will probly go with suede to give it a softer touch. I jist need to figire out how to cober where it goes from suede to carpet
