Posted: Thu May 17, 2012 11:37 am Post subject: Iron Duke Awesome-ness? |
http://www.nickariasjr.com/engine-blocks-gm-pontiac4.asp
Iron duke with an available LSx head bolt pattern? This is kind of cool! But obviously if I had 3k of disposable income to spend on a 4cyl, I would probably have other projects going...
Wonder what kind of reliable power could be made. _________________
Posted: Thu May 17, 2012 12:40 pm Post subject: |
| Just out of curiosity, how does that engine stack up to the Ecotec? I'm trying to understand why somebody would be interested in that old engine vs. newer? |
Posted: Thu May 17, 2012 1:33 pm Post subject: |
the only logical reason I could see for this kind of development is maybe for a racing class to where there is a displacement limit regulation, but even so, I'm with Jon, to where, there must be better platforms that have already been designed, than to spend the time/effort/money into this.
just my humble $.02 |
Posted: Thu May 17, 2012 3:33 pm Post subject: |
Is for fun. Like stretchy pants. _________________ A redline a day keeps the carbon away! |
Posted: Thu May 17, 2012 3:39 pm Post subject: |
| Quasi-Traction wrote: | the only logical reason I could see for this kind of development is maybe for a racing class to where there is a displacement limit regulation, but even so, I'm with Jon, to where, there must be better platforms that have already been designed, than to spend the time/effort/money into this.
There is almost always a "better" platform, this is just for funsies! Turbo'd iron duke would be crazy fun in a cut up 3rdgen. _________________
Posted: Thu May 17, 2012 4:24 pm Post subject: |
| QwkTrip wrote: | | I'm trying to understand why somebody would be interested in that old engine vs. newer? |
Racing classes where OHC is not allowed, or are required to run a single cam motor. There are several of them, Pro-4 Stock comes to mind. |
jchaussee Member
Posted: Thu May 17, 2012 5:29 pm Post subject: |
| Those heads are so flippin cool. Not the 4 cylinder buy the hemi heads for a ls block |
Posted: Thu May 17, 2012 5:35 pm Post subject: |
| jchaussee wrote: | | Those heads are so flippin cool. Not the 4 cylinder buy the hemi heads for a ls block |
Hemi heads actually have terrible combustion aspects. The only hemi head I have is for a motorcycle... _________________ A redline a day keeps the carbon away! |
Posted: Thu May 17, 2012 7:15 pm Post subject: |
| Twilightoptics wrote: | | Is for fun. Like stretchy pants. |
You always have a way of explaining things so I can understand. |
Posted: Thu May 17, 2012 7:35 pm Post subject: |
Thanks for making it weird, Paul, but I couldn't agree with you more. There are always going to be crazy people (like myself ) with disposable income and the need to have a one-off race car. |
flea Member
Posted: Thu May 17, 2012 7:42 pm Post subject: |
| aaron_sK wrote: | | Twilightoptics wrote: | | Is for fun. Like stretchy pants. |
Thanks for making it weird, Paul |
Paul's weird??
Who took a perfectly good stretchy pants thread and turned it into a race car thread. Weirdo. _________________ Killing mailboxes since 2009 |
Posted: Fri May 18, 2012 9:44 am Post subject: |
| Quote: | | Hemi heads actually have terrible combustion aspects. |
Seriously? Why? is the quench bad? Valve Shrouding? Why is a hemispherical combustion chamber undesireable?
not being factious, I'm genuinely curious. |
Posted: Fri May 18, 2012 10:45 am Post subject: |
There is no quench. The whole chamber is open. Which means you have to use a seriously domed piston to get any kind of compression. There are lots of further theories about heat loss and because of which insufficient fuel burning.
There is a reason hemi's went away - emissions, they burned like crap. Then once emissions technology caught up, they reintroduced a redesigned one.
Think of how much better and how much less timing the heart shaped chamber vortec design is to an open chamber 70s head design. Both still have quench.
In both the effective chamber is literally a top of a dome. Piston is usually flat or close to. Hemi and Dome makes a slice dome shaped chamber, also not good to burn completely.
They have advantages, when there is more than two valves they flow great and they resist detonation better than conventional cylinders. Hence why Top fuel cars use that style chamber - lots of boost. _________________ A redline a day keeps the carbon away! |
Posted: Fri May 18, 2012 5:06 pm Post subject: |
| Twilightoptics wrote: | | they reintroduced a redesigned one. |
And by "redesigned" you mean not actually a hemispherical head!  |
Posted: Sat May 19, 2012 12:38 am Post subject: |
That's kind of what I had theorized, but good info, nonetheless. |
