Tire size calculator?
PostPosted: Thu May 10, 2012 11:45 am    Post subject: Tire size calculator? Reply with quote
How many of you guys knew of/use the miata tire size calculator? I've used it for sizing tires/wheels for awhile and it's come in handy. Well, I just found an even more indepth one that shows wheels offset/backspacing and a host of other junk. Just thought someone else might get some use out of it
http://www.rimsntires.com/specs.jsp
PostPosted: Thu May 10, 2012 1:03 pm    Post subject: Reply with quote
Thanks! I use the miata.net one all the time.
PostPosted: Sat May 12, 2012 4:04 pm    Post subject: Reply with quote
I always use Wallace racing's calculator if I'm just dealing with tire heights. It's quick and easy.
http://www.wallaceracing.com/tire-aspect-calc.php
When I'm dealing with wheel fitment I use willtheyfit.com
http://www.willtheyfit.com/index.php?width=285&aspect=40&diameter=17&wheelwidth=9&offset=-5&width2=275&aspect2=35&diameter2=18&wheelwidth2=11&offset2=0&Submit=Submit
PostPosted: Tue May 15, 2012 7:18 am    Post subject: Reply with quote
Rimsntires.com is pretty Nice but it it won't even let me choose the wheel/tire sizes that I want!
