nonsensekid20 Member
Posted: Sun May 20, 2012 12:12 pm Post subject: Fuel pump strainer |
Alright, so I'm making my own carb pickup with compression fittings, 3/8 metal line, and a strainer on the end. Only, I need to find one that will work with that setup. I found a delphi that is for a 91 5.0, but again, don't know if that will work since it is a T setup. ( where the line is the I part and the filter is the _ part if that makes any sense.) I think I need one where I can make a 90* in the metal and have the sock sticking straight out.
Help please  |
