Another dumb question
jchaussee
PostPosted: Sun Apr 29, 2012 2:41 pm    Post subject: Another dumb question Reply with quote
So should I put fuel pressure gauge before or afyer mechanical fuel pump. And same with the regulator when I get one?
PostPosted: Sun Apr 29, 2012 4:19 pm    Post subject: Reply with quote
I'm assuming this is for a carb application. EFI would be different Wink
Fuel tank --> fuel filter --> mechanical fuel pump --> fuel pressure regulator --> fuel pressure gauge --> Carb
jchaussee
PostPosted: Sun Apr 29, 2012 4:24 pm    Post subject: Reply with quote
Sweet. Thanks
PostPosted: Sun Apr 29, 2012 5:00 pm    Post subject: Reply with quote
Jake nailed it. The pressure behind the regulator is irrelevant and there is no pressure behind the pump.
FWIW I like to run a filter before the pump and another finer one before the carb. The modern gasahol cleans stuff out like you would not believe.
jchaussee
PostPosted: Sun Apr 29, 2012 7:17 pm    Post subject: Reply with quote
I just replaced the big inline filter before pump. I am going to replace the filter the screws into carb this week. I need to cut some of the hard line from pump to carb to have enough room for gauge and regulator. Will a cuyyer for copper pipe work
PostPosted: Sun Apr 29, 2012 9:50 pm    Post subject: Reply with quote
Peanut cutter is your best bet. Any hardware store will have 'em cheap, or borrow one from a plumber.
You might also consider renting a flaring tool to throw flares on the lines. I have seen clamped rubber hoses slide right off of straight-cut steel lines.
jchaussee
PostPosted: Mon Apr 30, 2012 4:42 am    Post subject: Reply with quote
I was thinking about buying the flaring tool kit they have at harbor frieght. I know that they are cheaply made in a foriegn land, but I figure I will only use it a few times.
PostPosted: Mon Apr 30, 2012 9:28 pm    Post subject: Reply with quote
Harbor freight tools are hit-and-miss in my opinion. Don't know what your budget is, but for something critical, I'd spend the extra money and get a good one.
PostPosted: Mon Apr 30, 2012 9:44 pm    Post subject: Reply with quote
I have the summit double flaring tool and it works awesome. Think it was pretty cheap too.
PostPosted: Tue May 01, 2012 8:06 am    Post subject: Reply with quote
I bought the Napa flaring tool and it was crap. I took it back.
PostPosted: Tue May 01, 2012 5:11 pm    Post subject: Reply with quote
When I did my brakes I borrowed Al's flaring tools. One he had was a VatoZone special and the other was Napa. They were basically the same quality. Laughing
Regardless, the flares in this case are only holding the hose clamps in place, so they don't need to be pretty. I would just rent the tool.
PostPosted: Tue May 01, 2012 5:35 pm    Post subject: Reply with quote
Best way is to use a double flaring tool and only HALF flare with the first step. It gives you a nice NUBB to keep the hose and clamp from sliding off. Works awesome.
jchaussee
PostPosted: Sun Jun 24, 2012 11:34 am    Post subject: Reply with quote
So I figured I will just go out and buy a flaring tool today. Was hearing good thongs about home depot tool. Anybody use it and have success? Is from their rigid line
PostPosted: Sun Jun 24, 2012 12:14 pm    Post subject: Reply with quote
Works great! Just take your time.
jchaussee
PostPosted: Sun Jun 24, 2012 2:43 pm    Post subject: Reply with quote
So I just hooked up gauge. Before I even hooked it up it read 2 psi . The gauge that is. Is that normal or is it faulty out of the box. And then when I fires it up its reading about 10 pai which I know is high , but it is rather erratic. Is that normal
PostPosted: Sun Jun 24, 2012 7:05 pm    Post subject: Reply with quote
What gauge is it?
jchaussee
PostPosted: Sun Jun 24, 2012 7:42 pm    Post subject: Reply with quote
Cheap spectre mini gauge. It bounces all over erratically
jchaussee
PostPosted: Sun Jun 24, 2012 8:27 pm    Post subject: Reply with quote
I'm sure it works just as well as the no name chinesium cheap starter....
PostPosted: Sun Jun 24, 2012 8:35 pm    Post subject: Reply with quote
Laughing
At least run the Summit brand gauge.
BTW, don't get a liquid filled, it goes south as it gets hot.
