sportlines
RK82
1982 Pontiac Trans Am
PostPosted: Thu Mar 08, 2012 7:58 pm    Post subject: sportlines Reply with quote
kind of a dumb question but does the flat coil go up in the pocket or down in the control arm?
PostPosted: Thu Mar 08, 2012 8:47 pm    Post subject: Reply with quote
Up.
Bottom of the coil is aligned in the pocket on the a-arm so that it covers one of the small holes at the bottom but not both.
RK82
PostPosted: Tue Mar 13, 2012 8:37 pm    Post subject: Reply with quote
ok, that's the way I have them, I think there indexed properly in the control arm, I'll have to check later.
the car sits kinda funny
LF-26 1/2"
RF-26 3/4"
LR-26 3/4"
RR-27 5/8"
PostPosted: Tue Mar 13, 2012 8:44 pm    Post subject: Reply with quote
Looks like something wrong with the RR pushing weight over onto the LF? or I suppose it could be the LF sitting lower pulling the RR up.. LOL
PostPosted: Tue Mar 13, 2012 9:35 pm    Post subject: Reply with quote
Check the rear isolators and the clock position in the front a-arms. That's what indexes all the springs.
RK82
PostPosted: Tue Mar 13, 2012 9:44 pm    Post subject: Reply with quote
the rear isolators are long gone, they were the first things to go when I original lowered it 3 or 4 years ago, I'll have to check the fronts next time I have it in the air
Any one ever cut sportlines?
PostPosted: Tue Mar 13, 2012 9:54 pm    Post subject: Reply with quote
Let 'em run a couple weeks before you cut anything. They always settle a bit.
