91 LO3 TBI high idle after motor warm.
Red Bird
1991 Pontiac Firebird
PostPosted: Sun Feb 26, 2012 3:50 pm    Post subject: 91 LO3 TBI high idle after motor warm. Reply with quote
Hey guys, its been a while since i posted here, hope your all doin well. I just pulled my 91 LO3 out of storage, and cruised it over the weekend. I fired her up and she ran fine. I ran the car pretty hard (its been 5 months since i dropped the hammer).
today i went out to warm up the car, and after a couple minutes i went to go for a cruise, normally the revs sit at 1500 and then after she warms up and i rev the engine once the revs drop to 800-900rpm. Today the revs refused to drop below 1500 even after the motor was warmed up. In neuteral the motor now idles at 1500.
i pulled my open element air cleaner, and checked for vaccum leaks and could find none. i am going to check out my TPS but was wondering if this could be a coolant temp sensor issue. If anyone has any ideas or run into this problem themselves id love to hear em. thx
1991 Firebird L03 T-5
PostPosted: Sun Feb 26, 2012 5:16 pm    Post subject: Reply with quote
If CTS craps out it will be running way rich.
Clean the IAC then do the normal minimum air and TPS adjustment.
Red Bird
PostPosted: Sun Feb 26, 2012 5:39 pm    Post subject: Reply with quote
Other than the high idle problem, the car runs good, ill cleanin the IAC and then make sure the TPS is adjusted correctly, thx aaron, ill let you know how it turns out thx again.
Isaac
PostPosted: Sun Feb 26, 2012 9:25 pm    Post subject: Reply with quote
My '91 L03 used to do the same thing. Cleaning the IAC seemed to fix the problem. Cool
Red Bird
PostPosted: Tue Feb 28, 2012 7:30 am    Post subject: Reply with quote
So i took my car down to my buddys shop, it was running real rich on the way there, we hooked a scan tool up to it, no codes but the coolant temp was reading at 35 degrees. swapped the coolant temp sensor, fixed the high idle. runs even better than before.
