BluFbdy Member
Posted: Mon Mar 05, 2012 7:15 pm Post subject: headlight retainer nut and pull down motor |
just like the title says I need that god forsaken plastic nut that holds in the headlight switch and a good pull down motor, you can grab the hatch and lift it up while its locked a good 3 to 4 inches , seems to be just sliding along the track _________________ If you expect a kick to the balls and get a slap to the face its still a victory
