Posted: Tue Feb 07, 2012 7:19 am Post subject: Best coolant flush |
Hey guys, I'm battling the the previous owners lack of cooling system maintenance in the lt1. I've flushed it about 4 or 5 times and it still looks like swamp thing is living in my radiator. The radiator, water pump, heater core, and hoses are all brand new.
So my question is what is the best, most aggressive, harmful to the environment, stuff to clean out the rust and crap in the block?
-jake _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Tue Feb 07, 2012 10:12 am Post subject: |
| If you can find an OLD bottle of prestone flush. From like 15 years ago. That stuff kicked ass. They have redone it so that some dishwasher soap I swear would be better. |
Posted: Tue Feb 07, 2012 5:58 pm Post subject: |
| There used to be some old school powder that was awesome. The water would actually get hot when you added it.. major chemical reaction. Bout 4 or 5 years ago it disappeared from our shelves though. Now its all pretty much just soapy water. |
Posted: Tue Feb 07, 2012 9:55 pm Post subject: |
This is the Cascade Crew, duder. You need to use a proper Cascade-approved cleaning solution:
Brandon suggested that to me one time because he had read it somewhere and we were out of ideas. Sh*t works like a charm. Here's what I did:
Dumped the coolant, pulled the stat, filled with water and added a generous amount of the liquid soap for automatic machines. Ran the car up to temp then dumped it out and did a normal flush & fill with the T in the heater line and all that jazz. |
Posted: Tue Feb 07, 2012 10:08 pm Post subject: |
| I forgot all about that. Worked well eh? |
Posted: Tue Feb 07, 2012 10:14 pm Post subject: |
It did indeed. I wish I would have videotaped it.
The engine I used it in had been ruined by someone's use of radiator "repair" crap. The dish soap turned the clumpy clay sh** into a fine slush that just ran right out. The trick is to use the stuff for automatic machines so it doesn't aerate. |
jchaussee Member
Posted: Wed Feb 08, 2012 9:48 am Post subject: |
| So I have never really flushed a car. I have drained radiator, but never flush. So question is does the t thing go into one of the hoses that go into firewall and if o which one? |
nonsensekid20 Member
Posted: Thu Feb 09, 2012 11:28 pm Post subject: |
| I was reading around and people have been saying dump 5 quarts of vinegar in and top off with distilled water and run it up to temp. Probly hotter temp than normal. Then flush. I'm glad this came up though because mine is really bad. I just paid $70 for eagle tire to do nothing. |
Posted: Fri Feb 10, 2012 12:01 am Post subject: |
Fleetguard coolant restore is epic. _________________ A redline a day keeps the carbon away! |
Posted: Fri Feb 10, 2012 6:27 pm Post subject: |
| How hot should I get the car after adding the vinegar and water? |
Posted: Fri Feb 10, 2012 9:34 pm Post subject: |
Dude, WTF is vinegar going to do? It's just a mild acid. May as well put orange juice in it.  |
Posted: Fri Feb 10, 2012 9:46 pm Post subject: |
| It will get rid of the odor from last week's chicken pot pie that is clogged in the return hose. |
Posted: Fri Feb 10, 2012 10:43 pm Post subject: |
| Summer's Eve Coolant Flush |
Posted: Sat Feb 11, 2012 4:37 am Post subject: |
| That's like using ky as differential lube... |
Posted: Sat Feb 11, 2012 8:18 am Post subject: |
| No, it's called KY Axle Lube. |
Posted: Sat Feb 11, 2012 8:20 am Post subject: |
All sorts of wrong here. My car does not have, a not so fresh feeling thank god. _________________ A redline a day keeps the carbon away! |
Posted: Sat Feb 11, 2012 8:24 am Post subject: |
The kids continue to put the 'Ew' in 'Crew.'  |
Posted: Sat Feb 11, 2012 8:28 am Post subject: |
| And that brings up a Two Live Crew song... |
Posted: Sun Feb 12, 2012 6:45 pm Post subject: |
| The buildup inside the radiator is calcium buildup from tap water. Vinegar is the same thing you use to clean out coffee pots with calcium buildup. It needs to get hot, then sit for some time and dumped and flushed. I was just asking how hot I should get the car before it gets dumped. What is in the Cascade complete that cleans out the radiator? |
