BluFbdy Member
Posted: Mon Jan 09, 2012 7:35 pm Post subject: so i need a favor from someone.... |
I need somebody to probe their tach wire for me with a dvom set to AC, at idle mine is all over the place and its screwing with my remote start, at idle it should read a consistent voltage and when you raise rpms it should rise. Prove at the negative side of the coil on the white wire Por favor. I want to make sure its my car having an issue my remote start was fine before the icm crapped out on me and I swapped it,
Normally external coils are spot on with voltage but I wanna make sure its not a thirdgen
thing before I put a signal generator in
TIA _________________ If you expect a kick to the balls and get a slap to the face its still a victory
