| What should I do to keep my car on the road? |
| Suck it up and wait and see if the T5 lasts |
50% |
[ 3 ] |
| Revert to 700r4 |
50% |
[ 3 ] |
| Total Votes : 6 |
Leejo2005 Member
Posted: Fri Jan 06, 2012 3:26 pm Post subject: Tranny issues |
The old NWC T5 in my firebird is getting to the point that I don't feel comfortable putting miles on it every day. It whines very loudly, especially in 5th to the point where its impossible to hold a conversation in the car. I don't have the money to get the T56 (glory) that I'd like, but I need this car to drive 50+ miles every day. Basically I need a solution to keep the car on the road until I get all of the parts I need for a T56 swap. The car was originally 4-speed auto.
I still have all of the parts from the swap minus a good 700r4. My dad is willing to help me out by buying a junkyard 1988 700r4. I have a friend that is willing to rebuild it for me since I don't have the special tools for it.
In the end it looks like it would set me back a few hundred for the rebuild, and about half a day to do this.
Scandalous for sure.
This all seems a bit crazy,but to me but it seems like a reasonable way to keep the car on the road.
Also, my wife can't drive stick and her car is a turd destined for hell (Ford Taurus).
Should I do this? Should I wait until I can afford a T56? |
Posted: Fri Jan 06, 2012 8:34 pm Post subject: |
You can afford to rebuild the 700R4 but not the T5?  |
Leejo2005 Member
Posted: Fri Jan 06, 2012 8:55 pm Post subject: |
| I can't even find new gears for the NWC T5. |
Posted: Fri Jan 06, 2012 9:00 pm Post subject: |
Just buy another one!
I would bet you I could buy ten used T5's for what you would pay a tranny shop to rebuild one 700R4. |
Leejo2005 Member
Posted: Fri Jan 06, 2012 9:14 pm Post subject: |
| Well if I could find one locally for cheap enough I might be into it. |
Posted: Sat Jan 07, 2012 11:18 am Post subject: |
Pick N' Pull sells them for something like $135. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sat Jan 07, 2012 11:21 am Post subject: |
| Check craigslist. Usually all Mustang and Jeep stuff but sometimes they come up. |
Posted: Sat Jan 07, 2012 12:46 pm Post subject: |
Doubt your whine is gears in the T5 unless you've run it low on oil for a long time.
Change the fluid and drive it.
Or put a brass/bearing kit in it for $150. _________________ A redline a day keeps the carbon away! |
Leejo2005 Member
Posted: Sat Jan 07, 2012 7:38 pm Post subject: |
The gear box was rebuilt 5 months ago by tranny shop to correct whine and made no improvement, been getting worse since.
All of those kits are just bearings and misc parts or WC gears.
I spent this afternoon combing around local yards and making phone calls with no luck finding a T5. I'll try looking a bit more next week.
I've had to stop driving it. I drove it to Bremerton today and it made this horrible noise when shifting from 4th to 5th twice and again when I took it out of 5th. |
Posted: Sat Jan 07, 2012 9:37 pm Post subject: |
| Have you talked to the shop about this? Give them a chance to correct their mistake. |
Posted: Sat Jan 07, 2012 11:11 pm Post subject: |
| I just saw one on Cl I think yesterday for cuople hundred. |
Leejo2005 Member
Posted: Sun Jan 08, 2012 1:59 am Post subject: |
| Thanks! I don't know how I missed it. |
91camaro_rs Member
Posted: Mon Jan 16, 2012 1:57 pm Post subject: |
is it for a V6 or V8?
i have a rebuilt 700r4 with stage 1 shift kit and vette servo in it, has 17k miles on it, but its for a V6 _________________
Leejo2005 Member
Posted: Mon Jan 16, 2012 8:50 pm Post subject: |
| I just got a working one for free from a wrecked 1987 T/A. I'm just waiting on a flexplate and I'm good to go. |
Leejo2005 Member
Posted: Wed Feb 08, 2012 11:42 am Post subject: |
| Seeing as how I have my T5 up for grabs I figured I should put another transmission in the car. |
Leejo2005 Member
Posted: Wed Feb 08, 2012 11:52 am Post subject: |
| I love how whenever I do any electrical work it looks like I've totally ruined the car. I had to pull all the wires apart to find the ones I need to reroute. For the TCC and VSS I ran them through a grommet I insalled where the speedo cable previously was run. I did also make a neat harness for it and used insulated hose clamps to hold everything neatly in place. It's taking a lot of time to do all of this but I'm much happier than in the past when I was lazy. |
