Leejo2005 Member
Posted: Tue Jan 03, 2012 10:32 am Post subject: Cold Start Issues |
For the last month or so the Firebird has been running super rich after a cold-start. It pegs the wideband gauge at 10:1 and barely runs. As it warms up it slowly comes up to about 12:1 then snaps into closed loop 14.7-15:1 and runs fine. If the car has been started within about the last 6 hours it doesn't do it.
I hooked up the laptop and I didn't see any weird sensor readings. I first suspected CTS but it was right on.
I'm running $6E ANZA on my car with cold-start injector delete kit. Vacuum at 20" at 900rpm fuel pressure at 43ish.
I'm puzzled with this right now. I haven't messed with anything on the engine or tune for a month or two before it started acting up. |
