Break up
Leejo2005
PostPosted: Sun Oct 09, 2011 5:18 pm    Post subject: Break up Reply with quote
So I finally have the new rear in the Firebird and have the brakes bled and sealed. I took it for a short drive to set the prop valve and I found that under no circumstance was I able to lock either the front or rear tires from 30mph. I have stock disks all around so I'm hoping that this is because my tires have too much grip for the stock brakes. Any thoughts?
It still stops pretty quick, but I thought stomping the pedal would at least get it to lock a bit.
PostPosted: Sun Oct 09, 2011 6:39 pm    Post subject: Reply with quote
stomp harder... or new pads, you should be able to lock 'em up with stockers once, the problem with the stock stuff is it overheats easier than the big brakes.
PostPosted: Sun Oct 09, 2011 7:06 pm    Post subject: Reply with quote
Mushy rubber lines, master leaking internally, booster bleeding pressure. Could be a lot of things.
Leejo2005
PostPosted: Mon Oct 10, 2011 1:22 am    Post subject: Reply with quote
I installed a rebuilt master cylinder for a 1988 with 4 wheel disks when I did this swap. It seems to be fine and the pedal feels normal. I had been able to lock the fronts at least when I had rear drums.
PostPosted: Mon Oct 10, 2011 12:52 pm    Post subject: Reply with quote
You did replace the prop valve when you did the swap?
PostPosted: Mon Oct 10, 2011 1:16 pm    Post subject: Reply with quote
You should be able to lock stockers as many times as you want to! There's no heat generated when the rotor is completely stopped. Wink The time when stock brakes aren't so great is when you have to do many high-speed braking maneuvers without giving the brakes time to cool. In that situation, you will get fade.
That being said, the stock brakes will definitely lock the tires when cool if everything is in order. Aaron's suggestions are a good place to start.
Leejo2005
PostPosted: Mon Oct 10, 2011 1:28 pm    Post subject: Reply with quote
I installed a wilwood adjustable prop valve. I was able to get the fronts to lock up this morning. Apparently the J65(4 disk) master cylinder has larger bore pistons. This makes for shorter pedal travel and higher pedal effort. I'm used to the J50(drum) master cylinder so I guess I just had to stomp harder.
PostPosted: Mon Oct 10, 2011 1:32 pm    Post subject: Reply with quote
Do you have verification for that master cylinder statement? I thought all thirdgens had the same master cylinder regardless of drum/disk rear? It was my understanding that the only difference was the prop valve.
You want to adjust your prop valve so that your fronts lock a little bit before your rears, but you do want to be able to lock all 4. Smile
Leejo2005
PostPosted: Mon Oct 10, 2011 2:29 pm    Post subject: Reply with quote
http://www.thirdgen.org/techboard/suspension-chassis/58295-master-cylinder-differences.html
The brakes feel fine and balanced now just takes more force on the pedal than before.
I did find out that LS1 rotors and C5/C6 calipers will clear my wheels Smile
PostPosted: Mon Oct 10, 2011 2:43 pm    Post subject: Reply with quote
Interesting. Good to know. So if I want less pedal travel on my Z06/LS1 setup (with much more caliper volume than stock!) I can switch to the J65 master cylinder. Cool.
PostPosted: Mon Oct 10, 2011 2:58 pm    Post subject: Reply with quote
What if you want less pedal effort AND less pedal travel? SOL?
PostPosted: Mon Oct 10, 2011 4:44 pm    Post subject: Reply with quote
Buy a hyroboost.
Leejo2005
PostPosted: Tue Dec 13, 2011 9:37 pm    Post subject: Reply with quote
Got the LS1 rears bolted on the 9 bolt today. I haven't hooked up the lines yet I still need banjo bolt washers. I ordered some brass rods today so I can weld up around the bolt holes and fill in the old bolt holes. I also had to have spacers made to make up the thickness of the back plate and keep the axle retained properly. All things considered I think it will be worth it.
