VSS
PostPosted: Mon Dec 05, 2011 5:11 pm    Post subject: VSS Reply with quote
I need to ensure that my VSS is sending 4000 PPM to the ECM.
How do I go about this. Is there a cable and a bit of software that I can get to look to see whats going on. I guess I'm asking about data logging, I don't necessarily want to make changes without adult supervision (can you imagine all the ways I could mess that up Shocked ) But I do need to know that I have the correct ppm going on.
Killing mailboxes since 2009
PostPosted: Mon Dec 05, 2011 8:21 pm    Post subject: Re: VSS Reply with quote
If you're using the original VSS then it's not.
PostPosted: Mon Dec 05, 2011 8:39 pm    Post subject: Reply with quote
Ok. it is the original VSS. The ECM is a 7730, what I have been able to find is that I need 4K to the ECM or it runs like dodo.
I can't find any info on which speed sensor I need to get, any suggestions?
Edit. the buffer box is robbing some of it, isnt it. would this take care of the problem?
[url][/url]
PostPosted: Mon Dec 05, 2011 8:49 pm    Post subject: Reply with quote
You need a '90 or newer multiport motor; TPI, veesix, or very early LT1.
There is also some scamming you can do with the ECM itself IIRC. We just had a thread on this not long ago...
PostPosted: Mon Dec 05, 2011 8:58 pm    Post subject: Reply with quote
He has a 91 VSS allready.. and the same vintage ecm. Don't think its the problem.
Or does tbi have a different VSS?
PostPosted: Mon Dec 05, 2011 9:02 pm    Post subject: Reply with quote
TBI retained the old-style VSS through '92.
Multiport cars went to the new style in '90.
*Edit: Quick check shows the following interchange:
'91-'93 Buick Roadmaster
'90-'93 Cadillac Fleetwood
'91-'93 Chevy Caprice
'90-'92 F-body 3.1L
'90-'92 F-body 5.0/5.7L TPI
'93' F-body 3.4L
'93 F-body 5.7L LT1
PostPosted: Mon Dec 05, 2011 9:07 pm    Post subject: Reply with quote
And there's your answer Jim.. you need to replace your brand new VSS...
PostPosted: Mon Dec 05, 2011 9:11 pm    Post subject: Reply with quote
Still got that receipt?
PostPosted: Mon Dec 05, 2011 9:23 pm    Post subject: Reply with quote
You can set a multi meter to HZ and then measure it. 60mph should get you 66hz (4000ppm*60mph*1hr/60min*1min/60sec=66pps or 66hz)
PostPosted: Mon Dec 05, 2011 9:57 pm    Post subject: Reply with quote
OK, I need to change to a sensor from one of these cars then?
'90-'92 F-body 3.1L
'93' F-body 3.4L
'93 F-body 5.7L LT1
No, of course not. Besides it's all used and such.
Leejo2005
PostPosted: Tue Dec 06, 2011 12:01 am    Post subject: Reply with quote
Firebirds got the 4K VSS a few years before the Camaros did. I'm not sure what year it started at but my '88 drivetrain has one.
PostPosted: Tue Dec 06, 2011 6:06 am    Post subject: Reply with quote
cool, so it sounds like I need a bird VSS from the same years along with bypassing the buffer box and I should be golden.
PostPosted: Tue Dec 06, 2011 8:21 am    Post subject: Reply with quote
'90-'92 F-body 3.1L
'93' F-body 3.4L
'93 F-body 5.7L LT1
The VSS in my 89 TBI is 2000 ppm, run from the back of the speedo head, the electronic one would be on the tailshaft - my 89 even has the harness pigtail at the tailshaft tucked up and away in the frame rails. My 92 (V6, 3.1) is 4000 ppm, driven from the tailshaft.
