ohms on coolant sensor
PostPosted: Sat Nov 12, 2011 8:02 pm    Post subject: ohms on coolant sensor Reply with quote
So since my digi dash came in the mail today Very Happy I am trying to see if I really need to install the temp sending unit they supplied "s8013", or if the stock one is that far off.
trying to find the ohm range unit "s8013", as well the stock gm one??
BluFbdy
PostPosted: Tue Nov 29, 2011 7:35 pm    Post subject: Reply with quote
slightly old, but im that bored and i just came across this, if i remember correctly the best way to do this is to measure each sensor cold, note the ohm load, then boil some water and measure the temp with a thermometer, stick them in and measure the ohm load
This just popped into my head when i read the post, i had to do this when i was taking electrical it may work it may not, but its worth a shot, are you jsut trying to see if the digidash one is the same as a stock gm sensor?
PostPosted: Tue Nov 29, 2011 7:50 pm    Post subject: Reply with quote
If you're doing that type of test you can't just measure it "cold" you need to throw it in some ice water or something. Minimum read on the GM unit is -24F IIRC.
