New toy
PostPosted: Sun Oct 09, 2011 10:26 pm    Post subject: New toy Reply with quote
Picked up an 01 ZR2 Blazer yesterday. Has a few things I need to work on, but overall in pretty decent shape. Got it for $3650.
Did the driver door hinge pins today. Cost $16, what a major difference for such a small investment. Has an ABS brake code C0265. Anyone here have any experience with that problem? I've searched and find conflicting answers to that it
There are receipts for a $3600 transmission replacement and new engine mounts Les Schwab receipts for new front CV shafts, calipers, one hub and rotor. The tires he put on it were $182 each. Unfortunately the spare tire was stolen he said just before I bought it. Sucks............but I got a crappy steel wheel and a 31 inch tire mounted for $50 today for it. Has a small dent in the right rocker panel and a small crease in the door. I can live with that.
There are a few small other things that need to be worked on, but it drives very nice and the 4 wheel drive works very well. Sure jumps when it's in 4 low and you stab the go pedal (petal) Wink
I'm thinking about losing the brush guard. Not sure if the looks of it will grow on me or not.
jchaussee
PostPosted: Mon Oct 10, 2011 9:31 am    Post subject: Reply with quote
i like those seats. wonder if they would would fit in a camaro
PostPosted: Mon Oct 10, 2011 10:58 am    Post subject: Reply with quote
Nice looking rig. I haven't seen two many two door models.
PostPosted: Mon Oct 10, 2011 12:16 pm    Post subject: Reply with quote
Nice! The guard almost goes with the spare carrier but I think it might look better without.
PostPosted: Mon Oct 10, 2011 12:58 pm    Post subject: Reply with quote
Nice color! I like seeing the two-door Be-lazers. Thumbs up
Bull bar sticks out too far and is silly. I vote you trade it to somebody for a smaller one.
C0265 comes back as 'EBCM Motor Relay Circuit - Low Feedback Voltage' which could theoretically be caused by a wiring fault anywhere. The interwebs consensus on it seems to be to check the grounds on the chassis under the driver, and failing that check connection at the brick, or possibly even a bad brick.
You can put Camaro seats into a first-gen S10, but not sure about the later ones, or if the inverse is true.
PostPosted: Mon Oct 10, 2011 1:07 pm    Post subject: Reply with quote
Yes, you can put first-gen S10 seats in a Camaro as well.
I'm not sure about later ones either.
PostPosted: Mon Oct 10, 2011 3:18 pm    Post subject: Reply with quote
Took a long time searching to find a 2 door, especially a ZR2 for a decent price. I liked the color of this one also. And the new trans and all the other recent repairs he put into it.
The brush guard is going bye bye. A kid at work buys and sells auction cars and he had a spare wheel to match my other ones. Got it for $45. They also took the front valance off to put the brush guard on. Well the kid here had one of those also for $20. So gonna pull the guard off and put it on CL this weekend.
I didn't have much time yesterday to check the brakes out. The warning light is on most of the time, but not all the time. I've read that a bad ground might be causing it, but I didn't find the one they mentioned under the drivers door yet.
Maybe this weekend I can look for it again.
PostPosted: Mon Oct 10, 2011 3:44 pm    Post subject: Reply with quote
Nice rig!
PostPosted: Mon Oct 10, 2011 4:25 pm    Post subject: Reply with quote
Those Zr2's are nice with the 1/2 ton axles and wider track width. I cant remember if those came with lockers front/rear too? I looked at a pickup when they very first came out.
PostPosted: Tue Oct 11, 2011 10:24 pm    Post subject: Reply with quote
I'm not sure it the front has a locker, but with the 4 wheel engaged it's sure hard to turn on pavement. Makes me think it does have one in the front. It was nice to look under it and not find a 7.5 rear in it.
Tonight on the way home it started to overheat. Looked and my water pump is leaking. So.........guess what I'm doing this weekend??? I drove it all the way home from dundee, oregon and it was full of water, so I think it's just bad timing that it chose to go out now on me.
PostPosted: Wed Oct 12, 2011 10:11 am    Post subject: Reply with quote
Found this on the blazer forum. It's an online vin decoder. You get your first lookup free. Thought this was pretty cool for free.
Here is what my ZR2 has. Turns out there were only 9 made with the exact same options as mine has.
http://www.compnine.com/vid.php?vin=1GNCT18W21K160641&x=14&y=8
Vehicle: BLAZER 2 DR
Year: 2001
Build Date: 2000-10-31
Found 139,314 vehicles matching your year and model in our database.
RPO Description Matches
UN0 RADIO,AM/FM,STEREO,SEEK/SCAN,COMPACT DISC,AUTO TONE,CLOCK,ETR STEREO W/CD PLAYER(UN0)
78,615
UP8 RADIO,PROVISIONS FOR STEREO INSTRUMENTATION STEREO RDO PROVISIONS(UP8)
139,314
U16 TACHOMETER,ENGINE TACH(U16)
139,302
U73 ANTENNA,FIXED FIXED ANT(U73)
139,314
U89 WIRING HARNESS,5-WIRE TRAILER 5 WIRE TRLR HARN(U89)
111,069
VXS VEHICLE - COMPLETE
139,314
V54 CARRIER,ROOF LUGGAGE(PAINTED) PAINTED RF LUGG CARR(V54)
125,211
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
139,146
XJJ TIRE FRONT 31 X 10.50R15LT/C BW R/PE ST TL OOR TIRE(XJJ)
23,544
X88 CONVERSION CHEVROLET CHEVROLET(X88)
MARKET BRAND CHEVROLET CHEVROLET(X88)(EXPORT)
139,314
YC3 COMFORT AND CONVENIENCE PACKAGE,#3(PERSONAL LUXURY) CONVENIENCE PKG #3(YC3)
COMFORT AND CONVENIENCE PACKAGE,#3(PERSONAL LUXURY) DECOR PKG LEVEL #3(YC3)
58,896
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
139,314
YD5 SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
139,314
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
139,314
YJJ TIRE REAR 31 X 10.50R15LT/C BW R/PE ST TL OOR TIRE(YJJ)
23,544
ZJJ TIRE SPARE 31 X 10.50R15LT/C BW R/PE ST TL OOR SPARE TIRE(ZJJ)
23,544
ZM5 SHIELD PACKAGE,UNDERBODY U/B SHLD PKG(ZM5)
25,953
ZM8 PACKAGE,ELECTRIC TAILGATE RELEASE AND REAR DEFOGGER ELEC T/GATE REL & RR DEFG PKG(ZM8)
123,870
ZQ3 DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION) DRVR CONVENIENCE PKG(ZQ3)
123,978
ZQ6 DRIVER CONVENIENCE PACKAGE III DRVR CONVENIENCE PKG III(ZQ6)
123,741
ZR2 "HIGH WIDER" PERFORMANCE PACKAGE,4 X 4 SPORT HIGH WIDER PKG(ZR2)
23,544
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
139,293
1SC PACKAGE-OPTION 03 (1SC)
52,365
1SZ PACKAGE OPTION- (1SZ)
133,503
45U EXTERIOR COLOR,PRIMARY (45U)
EXTERIOR COLOR-MEDIUM GREEN METALLIC (45U)
1,470
6WK COMPONENT FRT LH COMPUTER SEL SUP (6WK) SUSP(6WK)
23,544
64H TRIM COMBINATION CLOTH, BEIGE (H) (92) (64H)
7,998
64I INTERIOR TRIM,LIGHT BEIGE (64I)
7,998
7WK COMPONENT FRT RH COMPUTER SEL SUP (7WK) SUSP(7WK)
23,544
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
58,020
AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
124,548
AM7 SEAT,REAR FOLDING RR FLDG ST(AM7)
139,311
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
61,029
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
123,786
AV5 FRONT HIGH BACK BUCKET SEAT FRT HIGH BACK BKT ST(AV5)
139,314
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP)
139,311
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
123,786
B30 CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
139,314
C25 WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25)
123,870
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
125,592
C5C GVW RATING(5000 LBS) 5000 LB GVWR(C5C)
23,544
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
139,314
DH6 MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM) ILLUM S/S MIR(DH6)
64,944
DK2 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC,LH DEFOG(PAINTED) ELEC R/CON HTD PAINTED O/S MIR(DK2)
114,330
DK7 CONSOLE ROOF INTERIOR,CUSTOM,COMPASS & OUTSIDE TEMP RF CNSL(DK7)
55,593
D55 CONSOLE,FRONT COMPARTMENT FLOOR F/CMPT FLR CNSL(D55)
123,396
EVA TEST DVT, EVAP EMISSION REQUIREMENT EVAP EMISSIONS REQUIRED(EVA)
139,146
E55 GATE,END END GATE(E55)
139,314
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
111,003
FF4 ARM,TORSION BAR,SPRING ADJUST,LH TORS BAR SPR ADJ ARM(FF4)
64,638
FK3 ARM,TORSION BAR,SPRING ADJUST,RH TORS BAR SPR ADJ ARM(FK3)
64,638
GT4 AXLE,REAR,3.73 RATIO 3.73R(GT4)
27,522
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
60,537
JC1 BRAKE VAC POWER, 4 WHL DISC, 5,500 LBS BRAKE VAC PWR(JC1)
139,314
K18 REACTOR SYSTEM AIR INJECTION, ELECTRIC ELEC AIR INJECTION REACTOR(K18)
139,146
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
123,978
K60 GENERATOR,100 AMPERE 100 AMP(K60)
139,314
LIN PLANT CODE-LINDEN, NEW JERSEY (CPC) LINDEN, NJ PLANT CODE(LIN)
139,314
L35 ENGINE,4.3L(4.3W),CPI,V6,90 DEG 4.3W(L35)
139,314
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
129,513
NF7 EMISSION SYSTEM FEDERAL, NLEV FEDERAL EMIS NLEV(NF7)
111,126
NP1 TRANSFER CASE,ELECTRONIC SHIFT,TWO SPEED ELEK SHFT TRFER CASE(NP1)
42,015
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
69,462
N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33)
123,978
N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
139,314
PA3 WHEEL,15X7(ALUMINUM) AL WHL(PA3)
64,377
P16 CARRIER,REAR MOUNT SPARE TIRE RR MT WHL CARR(P16)
47,274
QJJ TIRE ALL 31X10.50R15LT/C BW R/PE ST TL OOR TIRE(QJJ)
23,544
RSA RESTRAINT - FRT SEAT, 208, AUTO, PASSIVE
139,314
SLM SALES PROCESSING - STOCK ORDERS
133,383
T61 LIGHTING,DAYTIME RUNNING DAYTIME RUNNING LGT(T61)
139,236
Rarity...
There are 9 2001 BLAZER 2 DR vehicles (0.006%) matching your exact options list. There are 12 (0.009%) with at least as many options.
PostPosted: Wed Oct 12, 2011 12:43 pm    Post subject: Reply with quote
Link is to a dead site?
PostPosted: Wed Oct 12, 2011 12:50 pm    Post subject: Reply with quote
Try using the link in my other post. Flea got it to work from there
PostPosted: Wed Oct 12, 2011 12:55 pm    Post subject: Reply with quote
Totally dead as well. Very odd.
These types of announcements don't come easy, but effective immediately Comp Nine will be closing its doors permanently.
Thank you to everyone that helped keep the site going and for allowing Comp Nine to serve the community for so many years.
PostPosted: Wed Oct 12, 2011 1:09 pm    Post subject: Reply with quote
Geez I just found it today and the same day it's gone.
Sorry guys (and gals)
PostPosted: Sat Oct 15, 2011 4:31 pm    Post subject: Reply with quote
Well got the water pump changed and a window motor installed. It's not much easier to do a window motor in this than a 3rd gen is.
Also got rid of that stupid brush guard and got a front valance and tow hooks back on it. Looks much better now I think.
The brush guard is for sale. First $50 takes it Wink
Now if I could just find the front fender flare extensions I'd be set as far as putting it back to stock looking condition.
PostPosted: Sat Oct 15, 2011 6:16 pm    Post subject: Reply with quote
looks good!
