Weight
Goto page 1, 2, 3  Next
PostPosted: Tue Oct 11, 2011 1:27 pm    Post subject: Weight Reply with quote
I hope i dont get flamed for this, but is there any weight to save by cutting out the stock frame anywhere? I read posts where people drop a couple hundred by tubbing the rear but what about other areas? I was mainly thinking the front. Im sure it would violate some rules somewhere but i dont plan on doing anything but drift autocross or drag. I was hoping to tube the entire front and tie it in with framing to the rear subframe.
Or am i just thinking too big and should get a lighter car?
PostPosted: Tue Oct 11, 2011 1:48 pm    Post subject: Reply with quote
Drag guys run tube chassis cars all day.
If you're worried about getting weight off the front I hate to break it to you but I know of a big 700lb savings to be had. Wink
PostPosted: Tue Oct 11, 2011 2:07 pm    Post subject: Reply with quote
Laughing I know. Iron block heads and intake come in at 650 lbs dry. So mine weights 625. Lol. If i go with a small block im only saving 200 pounds unless i get something with aluminum heads. With my v6 and bare minimum interior it still was 2950. I was hoping to mainly cut chassis weight before i think about another engine swap.
PostPosted: Tue Oct 11, 2011 3:29 pm    Post subject: Reply with quote
Just make more HP. It's so easy with your engine. Smile
IROCDave
PostPosted: Tue Oct 11, 2011 3:54 pm    Post subject: Reply with quote
Sorry, I cant help it. I wouldnt touch anything on the sub frames with a BBC sitting between the tires. Alluminum heads, intake, water pump, smaller raidator, relocate battery etc would all be better options.
What Aaron was leading youn into is the weight difference between an all cast iron BBC and a late model LS2+. You would save about 300+ pounds and have the same power potential with the latter.
PostPosted: Tue Oct 11, 2011 5:21 pm    Post subject: Reply with quote
I know, this is the last engine i play with before going to lsx.
PostPosted: Tue Oct 11, 2011 7:57 pm    Post subject: Reply with quote
That wasn't specifically where I was going with that, but you are correct, Dave. Laughing
Bottom line is that we are dealing with a frame and suspension that was robbed from a fullsize car with no consideration given to weight.
If you wanted to go fast around corners you would be building a full tube-framed car, or an MX5 or E30. But where's the fun (and cost savings Razz) in that?
PostPosted: Tue Oct 11, 2011 8:02 pm    Post subject: Reply with quote
Fullsize? It's malibu/s10 stuff. The chevelle/malibu are mid-size cars. Razz
And the 1st/2nd gens were nova, which was the "small" car.
PostPosted: Tue Oct 11, 2011 8:32 pm    Post subject: Reply with quote
Is the nova the best small vehicle with a V8 RWD? I kick myself for not picking up the Nova my friend had for sale. I love the camaro, don't like the weight.
PostPosted: Tue Oct 11, 2011 8:42 pm    Post subject: Reply with quote
You want to autocross the Nova?
*Edit: So I take it back Laughing
All the GM front suspension stuff was based off of the B-body... from 1959. Rolling Eyes Except for the MacPherson and the fact that it's bolted up underneath the rails.
I understand why they never changed it. It's cheap and strong and it works. It's not light, it's not small, and so it's not an optimal setup for going fast.
PostPosted: Tue Oct 11, 2011 8:56 pm    Post subject: Reply with quote
The full size cars impala's and such all had their steering behind the crossmember. not in front like the chevelle/malibu/nova.
Here's a pic of a 68.. notice the arm for the tie rod end behind the rotor. Also the front end uses radius arms forward of the lower control arm. By this time the chevelle was allready using the suspension we are used to.
And a pic of the lower control arm itself.
I just happen to have owned a 68 impala and chevelle. Wink
PostPosted: Wed Oct 12, 2011 8:57 am    Post subject: Reply with quote
The malibu front looks way more enticing than the camaro. Sigh. Maybe the best i could do is a tubular k member and just accept the weight.
jchaussee
PostPosted: Wed Oct 12, 2011 11:27 am    Post subject: Reply with quote
I guy on TGO redid his whole front end. I don't know how much wieght he loss though
PostPosted: Wed Oct 12, 2011 12:51 pm    Post subject: Reply with quote
Alright alright B, beat me up on the technicalities. Laughing
I stand by my basic argument though. They recycled antiquated technology into an alleged "sports" car to save money.
That's my basic plan! Wink Except I'm not even running a tubular since this thing will be street-driven and I drive through Tacoma (pothole hell) frequently.
PostPosted: Thu Oct 13, 2011 3:54 pm    Post subject: Reply with quote
Solution to too much weight: higher intake pressure. Wink
PostPosted: Thu Oct 13, 2011 5:44 pm    Post subject: Reply with quote
Or a 502 boss hog. Not much more weight savings can go on there.
PostPosted: Thu Oct 13, 2011 7:23 pm    Post subject: Reply with quote
Laughing so hard it hurts
Those are truly the stupidest things ever.
PostPosted: Thu Oct 13, 2011 8:11 pm    Post subject: Reply with quote
How about an LS3 with ~500hp?
Dude riding it was about 6'5" and in his 60's.... loving life!
PostPosted: Thu Oct 13, 2011 8:22 pm    Post subject: Reply with quote
For when a lifted diesel crewcab isn't enough to express your inadequacies? Laughing
PostPosted: Thu Oct 13, 2011 8:34 pm    Post subject: Reply with quote
LOL... that is one small winkie there Wink
Page 1 of 3
