carpet installed, now heater doesnt work
PostPosted: Sun Aug 21, 2011 8:04 pm    Post subject: carpet installed, now heater doesnt work Reply with quote
The black n gray combo doesnt look too bad, but now i need to trouble shoot my heater fan and left rear speaker
PostPosted: Sun Aug 21, 2011 8:11 pm    Post subject: Reply with quote
Speaker wires come up one side and then cross over at the b-pillar. I forget which way they go, but fortunately I have a car with no carpet so I can check for you. Very Happy
Heater is a molded triple-wire unit, blue yellow and orange, that comes from the HVAC control and heads through the firewall on the passenger side.
PostPosted: Sun Aug 21, 2011 8:18 pm    Post subject: Reply with quote
I probably pulled a wire loose, need to clean the controls anyways.
PostPosted: Mon Aug 29, 2011 8:17 pm    Post subject: Reply with quote
Got the fan working again...changed the fuse and cleaned the connections and is started working again...still don't have "high" but the next one up works and that's where it's staying. Very Happy
PostPosted: Mon Aug 29, 2011 8:22 pm    Post subject: Reply with quote
Maybe the high speed relay. All other speeds go through the resistor network.
PostPosted: Mon Aug 29, 2011 8:23 pm    Post subject: Reply with quote
Is this an A/C car, or a factory delete car? Only A/C cars got the relay, and it only works if you kept your A/C harness when you deleted the rest of it.
PostPosted: Mon Aug 29, 2011 8:25 pm    Post subject: Reply with quote
It was an A/C car that I converted years ago and I have the relay...a cube that the wires run through.
PostPosted: Mon Aug 29, 2011 8:27 pm    Post subject: Reply with quote
Try pulling the relay off and jumping the harness with a lead.
PostPosted: Mon Aug 29, 2011 8:34 pm    Post subject: Reply with quote
I'll try that tomorrow. Thanks.
PostPosted: Wed Sep 21, 2011 6:26 pm    Post subject: Reply with quote
Figured the out Left Rear speaker...blown. And it was fairly new. Ended up swapping it out for a really old Sony 3-way that originally came in John's (RSFreak) 83 Z28 around '94 or '95 when he bought it. Works great for my musical needs. Very Happy
