85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Sun Jul 31, 2011 5:36 pm Post subject: Fan Switch |
Cant find where to put this, think I got the wrong part
http://www.summitracing.com/parts/HYP-4028/ _________________
1985 Trans Am Recaro Option (AS5)
67,000 miles 5.0 TPI Hi Flow MAF
TPI Airfoil w/Bypass Flowmaster WS6 (.92g)
3:27 Borg Warner Posi K&N Filtration |
Posted: Sun Jul 31, 2011 6:01 pm Post subject: |
Passenger head between cylinders 6 and 8. |
Posted: Sun Jul 31, 2011 7:23 pm Post subject: |
Your fan switch has to be set higher then your thermostat temp, or the fan will run forever. |
Posted: Sun Jul 31, 2011 8:50 pm Post subject: |
I meant one other than the one he wanted. That style seems better. |
Posted: Sun Jul 31, 2011 10:24 pm Post subject: |
That last one posting seemed like a good deal and turns on fan early, but I would think that with only ten degrees of seperation if would pretty much be running consistantly |
Posted: Mon Aug 01, 2011 5:44 am Post subject: |
Radiator probe is nowhere near as accurate as a thread-in.
The difference in degrees doesn't really enter into it. All of them are 10-15* difference.
Looks like the right part, but be very careful with the connector. Al and I have both had those pop on connectors fail. |
alloy T56 Elitist
Posted: Tue Aug 02, 2011 12:30 am Post subject: |
I agree about the probe not being as accurate as a thread in one in the cylinder head. I'm using this switch from Hayden. It takes a little work to put in, especially if you have two fans. It can't handle both fans, so I have this switch turn on a 75 amp bosch relay. Works perfectly and the adjustability is great. I hook my scanner up and watch the engine temp and just set the fans to come on exactly when I want them to.
http://www.summitracing.com/parts/HDA-3651/ _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
redlava Member
Posted: Sun Aug 07, 2011 7:58 pm Post subject: |
Just thought I'd mention that I thought I found a nice low temp switch.. 205 on 190 off..
Then I installed it and it comes on just over 220.. wtf? So I look it up again to see about ordering another one, but this time I look in the computer info about the switch. There it says the on temp is in the range of 204-224! LOL I guess they covered their asses with that. |
85 T/A WS6 Member
Posted: Mon Aug 08, 2011 8:01 pm Post subject: |
Just remembered I have a 170 deg tstat should have went with the cooler switch? 176 Degrees On/166 Degrees Off? _________________
Posted: Mon Aug 08, 2011 8:16 pm Post subject: |
No.. you want the on/off temps to be above your thermostat temp. Otherwise the fan would never kick off at all. |
Posted: Tue Aug 30, 2011 12:17 am Post subject: |
Your ECU doesn't completely go into closed loop until 176*F. If you're running cooler than that your cars not going to be running the best that it can, unless you've gone in and edited all your values. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
