BluFbdy Member
Posted: Thu Jun 30, 2011 9:26 pm Post subject: 3pc spoiler parts |
so when grabbing my hood today I was inspired to put my spolier back on, nick gave me the drivers side and the hatch but I need the last piece lol and possibly the hatch piece as well, the bolt on the right side busted out and I dont totally trust it
Anyone got the pieces?[/list] _________________ If you expect a kick to the balls and get a slap to the face its still a victory
kurfbird Member
Posted: Fri Jul 01, 2011 5:44 pm Post subject: Spoiler |
with or without a third brake light _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
BluFbdy Member
Posted: Fri Jul 01, 2011 6:09 pm Post subject: |
Without preferably, IIRC third brake light is older style and my hatch currently has the glass mounted light the older ones are larger than.the newer ones _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri Jul 01, 2011 6:17 pm Post subject: |
Wouldn't say larger, but wider. I perfer the spoiler light vs the fat hatch light. _________________ A redline a day keeps the carbon away! |
BluFbdy Member
Posted: Fri Jul 01, 2011 6:28 pm Post subject: |
Me too but my original hatch got shattered so I had to get a 90s style hatch unless someone has an 89 hatch with a working light lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
kurfbird Member
Posted: Fri Jul 01, 2011 7:43 pm Post subject: Is the spoiler have the light in the center?? |
Is the spoiler have the light in the center?? _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
BluFbdy Member
Posted: Fri Jul 01, 2011 8:15 pm Post subject: |
If youve got the full 3pieces with the light ill take it lol ive got to figure out how to wire it tho cuz I dont have the arm to the little contact plate on this hatch _________________ If you expect a kick to the balls and get a slap to the face its still a victory
RoosterC Member
Joined: 24 Feb 2011 Posts: 43 Location: Federal Way, WA
1988 Chevrolet Camaro
Posted: Tue Jul 12, 2011 12:40 pm Post subject: Re: 3pc spoiler parts |
BluFbdy wrote: | so when grabbing my hood today I was inspired to put my spolier back on, nick gave me the drivers side and the hatch but I need the last piece lol and possibly the hatch piece as well, the bolt on the right side busted out and I dont totally trust it
Anyone got the pieces?[/list] |
I'd be willing to trade you
I just bought the hatch spoiler from Bruce, and I won't be needing mine anymore.
But I could use some help with the bondo _________________ Sink or Swm |
RoosterC Member
Posted: Tue Jul 12, 2011 1:02 pm Post subject: Re: 3pc spoiler parts |
But I could use some help with the bondo [/quote]
Or if you've got a tac-welder and some experience that would be the most preferred the job I do now can be some-what temporary but would need to last for a while. _________________ Sink or Swm |
BluFbdy Member
Posted: Tue Jul 12, 2011 10:35 pm Post subject: |
The 3 pc? If youve got all 3 id be willing to help lol im assuming you mean the holes lol theyre a PITA but im totally willing to help lol
I havent got a welder or I would have gone that route on mine, had a high rise I was gonna install but body shop wanted 300 to do just the spoiler and I kinda miss the lip lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Wed Jul 13, 2011 8:18 am Post subject: |
You don't need a welder, when I deleted my antenna I used sealer to prevent rust on the hole, then fiberglassed from the bottom of the fender hole, then sanded the fiberglass smooth then used body filler over the top and smoothed that into the lines of the fender.
Can't even tell my fender ever had an antenna mount. This is the route we're probably gonna go on doing a spoiler delete on a friend's car before paint as well.
I've also done the welding a patch under the hole and using body filler on top way, I personally would do fiberglass every time over welding. _________________ 84 Camaro Z28 - LS1/T56
BluFbdy Member
Posted: Wed Jul 13, 2011 11:59 am Post subject: |
Mine was fine til I went thru LA and shook the fiberglass loose lol thats whhy I looked into welding _________________ If you expect a kick to the balls and get a slap to the face its still a victory
RoosterC Member
Posted: Thu Jul 14, 2011 9:56 pm Post subject: |
Alphius wrote: | You don't need a welder, when I deleted my antenna I used sealer to prevent rust on the hole, then fiberglassed from the bottom of the fender hole, then sanded the fiberglass smooth then used body filler over the top and smoothed that into the lines of the fender.
I've also done the welding a patch under the hole and using body filler on top way, I personally would do fiberglass every time over welding. |
I've never worked with fiberglass, or body work for that matter. That's where I'd need some guidance, but you can teach me how to fish _________________ Sink or Swm |
RoosterC Member
Posted: Thu Jul 14, 2011 9:58 pm Post subject: |
BluFbdy wrote: | The 3 pc? If youve got all 3 id be willing to help lol im assuming you mean the holes lol theyre a PITA but im totally willing to help lol
I havent got a welder or I would have gone that route on mine, had a high rise I was gonna install but body shop wanted 300 to do just the spoiler and I kinda miss the lip lol |
I'm doing the same thing, I got lucky and the high rise that bob had is the same color as my car. So I bought it off Bruce and I'm not sure if I have the time to put it on before I take off, or if I'll have to wait until after I get back. _________________ Sink or Swm |
Posted: Fri Jul 15, 2011 9:13 am Post subject: |
RoosterC wrote: | I've never worked with fiberglass, or body work for that matter. That's where I'd need some guidance, but you can teach me how to fish |
I've done a bit, probably not as much as some of the other members on here. This is from the first time I painted my car back in high school when I first got it. I've done a fair amount of bodywork, bondo, fiberglass, paint prep and painting. Gonna repaint my car this fall again.
BluFbdy Member
Posted: Fri Jul 15, 2011 3:40 pm Post subject: |
HOLY BONDO BATMAN!
I normally try to bang out the dents as much as possible and put a layer of duraglass over it then shave it down, i normally have a small layer of glass over it as little as possible except for filling holes with lol im still toying around with mixture up here though, it used to be alot easier in az with 0 humidity so i could mix alot at once but now i just do little bits and mix as i go
id have no problem helpin you out, itd be awesome to come back to oak harbor i used to live in little valley up on SR20 about a mile before you get to the drive in _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri Jul 15, 2011 7:30 pm Post subject: |
Yeah, it needed it... As you can see the body line took a beating while it was parked. That was stage one of body filler applied by a 17 year old me. I did smooth all the dents as close as I could get them before I applied any bondo, there's no filler that's more than just barely a thin layer to smooth the surface in (like you're supposed to do). That pic was before it was sanded. Better to have too much than too little.
Duraglass is for deeper dents that you can't just smooth with bondo, it still is supposed to have a normal filler over the top of it as well. Bondo can crack if it's too thick, Duraglass generally won't crack as easily but it is difficult to sand and blend well. Hence why you Duraglass then smooth with Bondo on top. None of my dents were deep enough to require anything more than a little bangin' and some Bondo.
It was completely straight after I got done with it, but the rednecks who owned it before me ran the lawnmower into it a few times. I suppose that's what you get when you buy a cheap roller with zero rust and 60k miles that sat in someone's front yard for years and years. _________________ 84 Camaro Z28 - LS1/T56
RoosterC Member
Posted: Sun Jul 24, 2011 9:49 am Post subject: |
BluFbdy wrote: |
id have no problem helpin you out, itd be awesome to come back to oak harbor i used to live in little valley up on SR20 about a mile before you get to the drive in |
Sorry I didn't get back to you in a timely manner, I dont think I'll have time to do this before I leave this week. Only option I could think of is if you did it while I was gone and dropped the car back off at my house I don't know how long it would take but I'd be willing to devote the rest of my free time for it. I get off around 3p.m. and don't mind driving to you. I will P.M. you my number incase you're interested.
-Jon _________________ Sink or Swm |
jchaussee Member
Posted: Sun Jul 24, 2011 4:40 pm Post subject: |
If you filling holes, what I did to my antenna and my rear wiper, is I took a piece of aluminum flashing and jb welded it underneath, then duraglass( I prefer it over bondo) I usually try to sand it smooth enough for either then glazing putty or some lightwiegth bondo. But the end result with my black paint is you can't see it. Only things afteer all my body work you can see are door dings, which ticks me off cause I coulnt see them with primer and could only feel half of them. |
BluFbdy Member
Posted: Tue Jul 26, 2011 10:23 am Post subject: |
dammit i would love to bhut we're comingup on car toys tent sale and my free time is gone ive been working 12 hour shifts just to keep up with customer flow, our bay is short 2 guys currently and i get one day a week off (if im lucky) most of the time ive been getting called in and tent sale is just pure insanity
how long will you be gone for? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
