Posted: Sun Jul 17, 2011 8:59 pm Post subject: Anybody have experience with garage door springs??? |
Looks like I need to replace mine. One of the torsion springs over the door snapped in half I don't know when it happened, but when I tried to open the door this afternoon, the motor would only lift it about 6" before it stopped. When I disconnected the slide from the chain, the door dropped like a rock, fortunately it was only up those 6 inches. I ordered a pair of new springs, so I'll try my hand at them in a week or two. The only experience I have with them is to wind them up shortly after purchasing the house.
My broken spring...
which should look like this...
 _________________ 92 Camaro
Posted: Sun Jul 17, 2011 11:58 pm Post subject: |
Be careful, I am not sure if it's an urban legend or not, but I have heard tale of people being killed while attempting to replace garage door springs.
that said my dad did this with success when i was younger. |
Posted: Mon Jul 18, 2011 8:34 am Post subject: |
Thanks for the warning. They can kill you, that's no urban legend. I've only wound them up shortly after buying the house, but never removed or installed one. Looks pretty straight-forward and I should be OK as long as I don't do anything stupid  |
Posted: Mon Jul 18, 2011 9:35 am Post subject: |
Always had a professional do it. I work on Roll up doors on box trucks sometimes. Smaller version, still dangerous. _________________ A redline a day keeps the carbon away! |
MrMike98 Member
Posted: Mon Jul 18, 2011 10:24 am Post subject: |
Al
i have a pair of those exact springs-come get them..
Mike |
Posted: Mon Jul 18, 2011 10:57 am Post subject: |
| You're too late, but thanks anyhow. I ordered the pair yesterday. |
BigDaddyVu 12sec Club
Posted: Mon Jul 18, 2011 3:36 pm Post subject: |
becareful i know atleast 2 guys lost there fingers fix those springs _________________
IROCDave Member
Posted: Mon Jul 18, 2011 6:35 pm Post subject: |
| Use the correct tool or at a minimum 3' pipe wrenches. Set your ladder off to the side also. |
Posted: Mon Jul 18, 2011 10:05 pm Post subject: |
| IROCDave wrote: | | Use the correct tool or at a minimum 3' pipe wrenches. Set your ladder off to the side also. |
Believe it or not, the correct tool is a couple of lengths of 1/2" bar stock, a couple of feet long each. They go into the holes on the sides of the end caps and you use them as levers to wind (or unwind) the spring. And my ladder will be off to the side. |
Posted: Sat Jul 30, 2011 3:13 pm Post subject: |
Well, that was fun. Much easier than I thought it would be. The hardest part was persuading the old springs off the rod once I released the tension. Putting everything back together was pretty easy. I used a couple of 3/8" drive ratchet extensions about 12" long to tension the springs, I think I got a little too much because the door goes up soooo fast and easy now  |
