1987_sportcoupe Member
1987 Chevrolet Camaro
Posted: Mon Jul 11, 2011 1:20 pm Post subject: 305 T-5 |
| Will a T-5 from a 305 work with a 2.8? What about the clutch and hydraulics? |
Posted: Mon Jul 11, 2011 2:45 pm Post subject: |
Hydraulics work fine.
You'll need to get a v8 26 spline disc, and a v6 14?iirc spline disc and have the hubs switched out. _________________ A redline a day keeps the carbon away! |
Posted: Mon Jul 11, 2011 2:56 pm Post subject: |
| Is that easy to do? This is my first time doing a tranny swap like this |
Posted: Mon Jul 11, 2011 3:46 pm Post subject: |
Everything else is the same. The case, driveline, etc etc.
You'll need to use the speedo gear from the v6 to keep your speedometer right.
The hub switching has to be done by a professional. It takes special machines and rivets ,etc to be centered and balanced.
Find a "BRAKE AND CLUTCH" shop in your area. _________________ A redline a day keeps the carbon away! |
Posted: Mon Jul 11, 2011 8:58 pm Post subject: |
Go to South Side Brake and Clutch if you do this. It's right off south tacoma way. 54th and S. Washington which is about a block away from 56th and ST way. Real nice people there. _________________
Posted: Mon Jul 11, 2011 10:21 pm Post subject: |
| might as well get a V6 T5, they are quite plentiful in junkyards. you can probably make money if you sell the v8 T5. |
Posted: Tue Jul 12, 2011 5:35 am Post subject: |
| Xophertony wrote: | | might as well get a V6 T5, they are quite plentiful in junkyards. you can probably make money if you sell the v8 T5. |
14-splie T5's grow on trees, not worth the trouble. |
Posted: Sat Jul 23, 2011 5:20 pm Post subject: |
lol, I actually answered your other post, but pretty much what everyone's said is right, go to a JY and pull a V6 T5.
Make sure its out of an F-body, as the S-10 trans has the shifter closer to the main case, and wouldn't be a direct bolt-in. |
