85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Wed Dec 29, 2004 8:25 am Post subject: Code 13 |
My 1987 Z-24 CEL has been flashing me lately, so I pulled a 13 out, a hard code for "Oxygen sensor signal fault - signal too low"
I bought a oxy sensor from GMpartsdirect and it should be here soon.
I think thats what it needs, any thoughts ?
Thanks in advance,
Don _________________
Posted: Wed Dec 29, 2004 6:41 pm Post subject: |
| That's a good start. Was just working on an s10 today with that code. It should set anytime the throttle is open more then idle and the o2 sensor reading is low for 1 minute. So it can either be an o2 sensor, a fuel delivery problem causing lean condition for 1 minute, or a wiring/ecm problem. The s10 today turned out to be the o2 sensor ground. Replaced the 02 first but still had a problem, so i located the grounds/cleaned them and cleaned the ecm connections.. After that everything seems to be normal. I also made sure the fuel supply/pressure was good before I got to changing parts. |
Leejo2005 Member
Posted: Mon May 30, 2011 7:31 am Post subject: |
This thread is almost 7 years old. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
1967 Satellite Sport 383 |
Posted: Mon May 30, 2011 8:48 am Post subject: |
| Leejo2005 wrote: | | This thread is almost 7 years old. |
You are quite right, Sir Unnecessary-Bump.
popballz Member
Posted: Mon May 30, 2011 10:57 am Post subject: |
lol I got a 13 and a 45 code i need to work on fixing today! _________________ -Donald
Posted: Mon May 30, 2011 2:18 pm Post subject: |
Umm, you are the one who revived it.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Leejo2005 Member
Posted: Mon May 30, 2011 6:58 pm Post subject: |
| RSFreak wrote: | | Leejo2005 wrote: | | This thread is almost 7 years old. |
"you are the one" |
1999 Taurus SHO
1974 F-250 460
Leejo2005 Member
Posted: Mon May 30, 2011 6:59 pm Post subject: |
1999 Taurus SHO
1974 F-250 460
Posted: Mon May 30, 2011 7:00 pm Post subject: |
Dude, what? |
Posted: Mon May 30, 2011 7:42 pm Post subject: |
Brain hurt. _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Jun 01, 2011 8:38 pm Post subject: |
| I PEED IN THE POOL, YEAAYYYYYYY! |
Posted: Thu Jun 02, 2011 6:43 am Post subject: |
| This is madness... |
