Massive oil leak
PostPosted: Mon May 02, 2011 5:55 pm    Post subject: Massive oil leak Reply with quote
My T/A has a massive leak that I can't locate. It is somewhere on the back of the engine. My first thought was a leak between the intake manifold and the china wall. But there was oil on top of the manifold at the distributor so I figured it was the dizzy gasket. Replaced the gasket and it still leaks. It will go though a quart of oil per day at least. That seems like alot to be coming from the intake manifold. Is there anywhere that pressurized oil could be coming from? I don't wanna pull the intake if I don't have to.
PostPosted: Mon May 02, 2011 6:00 pm    Post subject: Reply with quote
We just had a post about this lol
Oil pressure sending unit behind the dizzy. If yours is located above the oil filter, it's possible your plug is leaking but very doubtful.
PostPosted: Mon May 02, 2011 6:04 pm    Post subject: Reply with quote
Funny you should mention that. When we first got the engine in the T/A the first time I turned it over oil came gushing out all over the driveway. Turns out Ian had taken the oil pressure sending unit before selling me the engine. We put a pipe plug in the hole sealed with teflon tape.
PostPosted: Mon May 02, 2011 6:05 pm    Post subject: Reply with quote
Thoroughly clean the area and run it without driving. Use a mirror, whatever, to see if it's coming from the dizzy or china or that plug.
Or a valve cover gasket Wink
PostPosted: Mon May 02, 2011 6:16 pm    Post subject: Reply with quote
I've used that green dye with good results in the past. I may give that a try too. Cool
PostPosted: Mon May 02, 2011 8:34 pm    Post subject: Reply with quote
John, I put a pipe plug in the lower port (by the pump) on that motor. I never touched the upper one. Buck says thats where your leak is.
91camaro_rs
PostPosted: Mon May 02, 2011 9:20 pm    Post subject: Reply with quote
haha this reminds me of when that happened to me, thought the intake manifold was leaking so i pulled it off just to figure i was missing an oil pressure sending unit Laughing Laughing
PostPosted: Tue May 03, 2011 12:45 am    Post subject: Reply with quote
I'd be really surprised if that upper port was the culprit. I seem to remember trying to put my autometer sending unit in that little port and I couldn't get the square head plug out of the block and eventually gave up. But, I have never had the best memory.
PostPosted: Sat May 07, 2011 8:00 pm    Post subject: Reply with quote
Yup, that is where it is leaking from. And yes, there is evidence that you attempted to remove the plug. Wink
PostPosted: Sat May 07, 2011 8:23 pm    Post subject: Reply with quote
Totally busted. Laughing
PostPosted: Sat May 07, 2011 8:46 pm    Post subject: Reply with quote
That damn thing wouldn't come out for nuthin'! We used penetrating oil, heat, and the candle wax trick all to no avail. Even with the dizzy out it was very difficult to get a wrench back there. We managed to mangle the crap out of the plug too. Sad
PostPosted: Sun May 08, 2011 12:46 am    Post subject: Reply with quote
I have a welder.....
PostPosted: Sun May 08, 2011 10:28 am    Post subject: Reply with quote
Good to know! Very Happy I figured that was gonna be the next option. I actually have a welder too, I just don't know how to use it! But hey, if you're down to do some welding, let me know when!
PostPosted: Fri May 13, 2011 9:43 am    Post subject: Reply with quote
Use a magnet and make sure that plug isn't brass.
You'll need the dizzy out. Are you guys sure that's the culprit?
PostPosted: Fri May 13, 2011 11:25 am    Post subject: Reply with quote
Maybe it's just me but if I couldn't get it out years ago, and you guys are having a hell of a time getting it out now why do you think it's leaking?
PostPosted: Fri May 13, 2011 2:01 pm    Post subject: Reply with quote
I'm with stupid
PostPosted: Fri May 13, 2011 6:30 pm    Post subject: Reply with quote
Pull distributor, clean up area as much as possible, move anything that will move out of the way. Get a oil priming tool and prime engine with a drill. If it's the plug in the sender hole it should start to leak pretty quick. If the plug doesnt leak then move on. I'm betting china wall, and I don't think that will leak when using the priming tool. It will need to be running for the china wall to leak.
PostPosted: Fri May 13, 2011 9:30 pm    Post subject: Reply with quote
Got the dye. Put it in the oil. Ran the car. Oil was seeping out past the plug. Pulled the dizzy. Had no luck removing the plug. Rolling Eyes
We were thinking the same thing. Oil was able to get past the plug, but we couldn't get it out. We were using a magnetic pointer when trying to identify where the oil was coming from and it stuck to the plug.
PostPosted: Sat May 14, 2011 12:59 pm    Post subject: Reply with quote
Can you post a picture of this dye? I need to get some for my oil leak.
BluFbdy
PostPosted: Sat May 14, 2011 2:01 pm    Post subject: Reply with quote
IIRC I had a hell of a time getting that,out as well, thats where my oil pressure sending unit is tied into, I had to use a special tool to get it out
