		| Author | Message |
		| aaron_sK Member
				|  Posted: Sat May 14, 2011 7:13 pm    Post subject: Whadya all think? |   |
 "Light Machine Grey." I figure it's a Chevy, and this way I can see everything that inevitably leaks out of it.
 Either way it's an improvement from before...
		| Back to top |  |
		| turbo_jimi Member
 1985  Chevrolet  Camaro Z/28
				|  Posted: Sat May 14, 2011 7:21 pm    Post subject: |   |
				| Looks clean. _________________
		| Back to top |  |
		| Xophertony Rodeo Queen
 1988  Pontiac  GTA
				|  Posted: Sat May 14, 2011 7:48 pm    Post subject: |   |
				| You did not mask the widshield?  |  |
		| Back to top |  |
		| Al Hasse Member
 1992  Chevrolet  Camaro RS
				|  Posted: Sat May 14, 2011 7:53 pm    Post subject: |   |
				|  	  | Xophertony wrote: |  	  | You did not mask the widshield?  |
 Looks like it has a big crack in it and probably needs replaced.
 Engine bay looks good. I used to see a lot of that color with my last employer
		| Back to top |  |
		| IROCDave Member
				|  Posted: Sat May 14, 2011 8:12 pm    Post subject: |   |
				| Looks like a good start, but needs some gloss black before putting together. |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat May 14, 2011 8:38 pm    Post subject: |   |
				|  	  | Al Hasse wrote: |  	  |  	  | Xophertony wrote: |  	  | You did not mask the widshield?  |
  	  | Al Hasse wrote: |  	  | Engine bay looks good. I used to see a lot of that color with my last employer  |
 I'll bet.
  	  | IROCDave wrote: |  	  | needs some gloss black |
 Don't worry about that. The entire exterior will be gloss black.
		| Back to top |  |
		| iansane Member
 1991  Pontiac  Trans Am
				|  Posted: Sun May 15, 2011 9:59 am    Post subject: |   |
				| Yup, it's an enginebay.
 Looks good dude.
		| Back to top |  |
		| Alphius Peanut
 1984  Chevrolet  Camaro Z/28
				|  Posted: Sun May 15, 2011 10:03 am    Post subject: |   |
				| Good start, what's next Aaron?
 On a completely unrelated note, I like working with engines. And wiring. And electronics.
 Also absolutely not related in any way whatsoever, Cows is pretty soon. I'll let you put the pieces of the puzzle together.
		| Back to top |  |
		| Quasi-Traction "I have petals"
				|  Posted: Sun May 15, 2011 10:23 am    Post subject: |   |
				|  	  | Quote: |  	  | "Light Machine Grey." I figure it's a Chevy, and this way I can see everything that inevitably leaks out of it. |
 That's all fine and good until you're messing around with something and happen to have dirty hands
  My white engine bay isn't that white anymore. _________________
		| Back to top |  |
		| RSFreak The other "John"
 1989  Chevrolet  Camaro RS
				|  Posted: Sun May 15, 2011 10:24 am    Post subject: |   |
				| Looks many times better than it did when we pulled that nasty motor!  _________________
		| Back to top |  |
		| popballz Member
 1989  Pontiac  Firebird
				|  Posted: Sun May 15, 2011 11:35 am    Post subject: |   |
				| looks great! thats gunna be a nice ride  _________________
 -Donald
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sun May 15, 2011 12:24 pm    Post subject: |   |
				|  	  | Quasi-Traction wrote: |  	  | That's all fine and good until you're messing around with something and happen to have dirty hands   |
 That was actually my goal here, Chris. I originally shot the thing gloss black, but then I sanded it down and went with the high-gloss grey. I figure I'll see everything easier, and it's easier to clean.
  	  | Alphius wrote: |  	  | I like working with engines. And wiring. And electronics. |
 In an equally unrelated note, you got a PM!
		| Back to top |  |
				|  Posted: Sun May 15, 2011 1:50 pm    Post subject: |   |
				| How did you prep the bay before spraying it? |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sun May 15, 2011 3:21 pm    Post subject: |   |
				|  	  | RSFreak wrote: |  	  | How did you prep the bay before spraying it? |
 Scrape off crud
 Spray with degreaser (I used 409, but the Purple stuff or oven cleaner would have been better)
 Hose out
 Sand with 120 on areas with flaking/rust, sand the rest with 220
 Degrease again
 Hose out again, let dry overnight under fans
 Spray with brake cleaner, let dry
 2 coats primer about 10mins apart
 2 coats color the same
 I'm not a painter, but it worked, so...
		| Back to top |  |
