Last call, going for scrap
Goto page 1, 2, 3  Next
PostPosted: Wed May 11, 2011 8:19 am    Post subject: Last call, going for scrap Reply with quote
Still have the following stuff (lots of people interested, not as many willing to come out to the woods. Razz)
Power mirrors with harness $15
Complete 4160 Holley (been sitting empty awhile) $30
Carter OEM intank pump for TPI cars. Was in Mike's parted GTA, replaced with Walbro $5
Plastic valve covers for big block $5
Factory centerbolt covers $10
Power antenna cable $5
L98 starter $10
TPI exhaust logs w/tubes $10
Pontiac GFX, the two lower pieces that go in front of the rear bumper, maroon $5
Complete TPI setup minus rails & injectors (manifold, distributor, ect.) $80 or will part out
Center brakelight off of an '87 Camaro $5
Headlight motors x2 $20
SBC heads pictured below $40
Camaro fenders and front nose (not lower spoiler) jobber pieces, not OEM, some small dings.
All of this will go for scrap if not picked up in a couple of weeks.
jchaussee
PostPosted: Wed May 11, 2011 8:57 am    Post subject: Reply with quote
What casting on the heads, and are mirrors same as on camaro?
PostPosted: Wed May 11, 2011 9:34 am    Post subject: Reply with quote
The mirrors came off of a Camaro. Wink
jchaussee
PostPosted: Wed May 11, 2011 9:43 am    Post subject: Reply with quote
ya.I saw after I looked at pics. I maybe interested in both if price is right and you can find harness for mirrors
PostPosted: Wed May 11, 2011 9:54 am    Post subject: Reply with quote
I will look for the harness later today.
$40 for heads, $15 for mirrors with the harness, $10 without it.
Do you come South much? I can deliver for gas money, but it's a 280 mile round trip for me.
jchaussee
PostPosted: Wed May 11, 2011 10:05 am    Post subject: Reply with quote
I live in renton now. Need to update profile. I def want mirrors. I need to do a little more research on heads to see if they would work well on my 327. And how much machine work will cost.
chevysquid
PostPosted: Wed May 11, 2011 1:59 pm    Post subject: Reply with quote
What CFM is that 4160?
1986 IROC Z-28
PostPosted: Wed May 11, 2011 2:07 pm    Post subject: Reply with quote
I wouldn't mind having the air/smog lines off the manifolds.
Also wouldn't mind the fuel rail only... but doubt you want to part out a tpi set.
Would need shipped to 72120home or 72116biz.
91camaro_rs
PostPosted: Wed May 11, 2011 5:30 pm    Post subject: Reply with quote
how much for the TPI setup? i only need runners and plenum but you probably dont wanna sell just those
and how much for valve covers?
im gonna have my plenum runners and valve covers powdercoated but if i bought a 2nd set that way i could just drop off the one set and not have to worry about not being able to drive my car
kurfbird
PostPosted: Wed May 11, 2011 5:33 pm    Post subject: Re: Need this stuff gone Reply with quote
Aaron
I am interested in the following stuff. If some one else gets to it before I can get down there no problems.
Power mirrors (have the harness somewhere too)
Pontiac GFX, have the two lower pieces that go in front of the rear bumper
Complete TPI setup (manifold, injectors, rails distributor, ect.)
TPI logs with air, also have air lines and diverter valve
Starter off of an L98
Also interested in
Hatch motor
Headlight motors
Exhasut manifolds
I can come down your way on a road trip. Message me with a price.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Wed May 11, 2011 7:20 pm    Post subject: Re: Need this stuff gone Reply with quote
Renton > Canada-ville. Wink PM me when you figure out what you want.
600 CFM. $50 picked up.
Also wouldn't mind the fuel rail only... but doubt you want to part out a tpi set..
If Luke buys the runners and upper plenum, you can have the rails and lines. Do you want the injectors too, or just the rails?
Looks like Jay wants the rails, so I guess the TPI set gets split. Maybe $50 for the valve covers, runners, and upper plenum.
kurfbird wrote:
Aaron
You got PM, duder.
PostPosted: Sat Jul 02, 2011 4:49 pm    Post subject: Reply with quote
Cleaned the entire shop out this weekend. Realized that you guys have trouble with claiming things and then never showing up. All of this will go for scrap in two weeks if not picked up.
PostPosted: Sat Jul 02, 2011 5:43 pm    Post subject: Reply with quote
I never noticed the response before, I'm sorry.
If you still have the rails, I would like them.
PostPosted: Sat Jul 02, 2011 5:51 pm    Post subject: Reply with quote
Is that magnaflow catback still there? 3"?
jchaussee
PostPosted: Sat Jul 02, 2011 7:01 pm    Post subject: Reply with quote
My bad. I still want mirrors. I will tryand make it out soon. Grahmn ain't that far from me I don't think
PostPosted: Sat Jul 02, 2011 7:43 pm    Post subject: Reply with quote
I still want that fuel tank, but we'll have to swap mine out at your shop. As soon as I get the 89 up and running, a new fuel pump is in order to go in the "new" tank. I still have to run about 1/2 to 3/4 of the fuel I have out before the swap can happen.
PostPosted: Sat Jul 02, 2011 9:55 pm    Post subject: Reply with quote
Rails w/out injectors will probably be like $8 to ship, so call it $15.
Yup. Nice and shiny. Come and get it. Very Happy
Mirrors and harness are in a box under my bench. PM me anytime for my address.
Just pull the pressure line, throw it in a bucket, and jump the fuel pump relay to the battery. Then pour the bucket(s) into the new tank. Wink
PostPosted: Sun Jul 03, 2011 2:26 pm    Post subject: Reply with quote
Info on heads:
305TPI casting (87-92), 1.84 intake and 1.5 exhaust, centerbolt style.
No, I am not interested in the heads or anything else in your list. Razz I do see you have failed to list the console clock, which I assume means it is tucked safely away awaiting my return. Very Happy If it is in fact under everything made of iron in your junk pile, then you've got some 'splainin to do.
PostPosted: Sun Jul 03, 2011 2:27 pm    Post subject: Reply with quote
Console clock is worth no scrap, and fits nicely in the rafters. Do you still want those doors?
PostPosted: Sun Jul 03, 2011 2:30 pm    Post subject: Reply with quote
Only if they're very straight.
Man, I need a truck.
Page 1 of 3
