Wolffy Member
Posted: Sun May 01, 2011 9:39 am Post subject: emissions question |
i gotta deal with either getting emissions or "moving" to a location that doesnt have them
my question is since i dont have an EGR valve will it pass or fail based on that?
im running the HSR with 24lb injectors & a 58mm throttle body
all other emissions crap is still on
thanxs |
Posted: Sun May 01, 2011 1:45 pm Post subject: |
| In Oregon I know they don't check for NOx emissions, which is what the EGR is for. Dunno about Washington though, I was under the impression Washington isn't as strict on emissions. |
Posted: Sun May 01, 2011 5:28 pm Post subject: |
WA doesn't check for NOx on the old cars.
Wolffy, where are you failing the test? |
Wolffy Member
Posted: Sun May 01, 2011 9:39 pm Post subject: |
i havent gotten it tested yet
im asking so i dont fail & have to spend $$$$ to fix a non-existant problem
id rather just get it licensed elsewhere so i dont have to deal with this crap, but .... |
Posted: Sun May 01, 2011 10:06 pm Post subject: |
Just run it in and check it once. Then fix anything that comes up. The first retest is free.
I've gotten a TON of crap past the sniffer in this state. Mostly just with Iso-Heat. |
