nonsensekid20 Member
Posted: Sat May 07, 2011 5:01 pm Post subject: Grinding noise |
Alright, so im driving along, and only when taking off and sometimes turning corners, a theres a type of grinding noise in the front end. I think it sounds like the exhaust flanges moving or hitting something. I have the doughnut gaskets put it. And with the studs for the collectors, if you try turning them without holding the top bolt, they'll spin, but if you put a wrench on the top and spin from the bottom its really difficult to turn. Too short of bolts? or something else?  |
Posted: Sun May 08, 2011 12:47 am Post subject: |
Sounds like wheel bearing. Or something else. Turning corners wouldn't indicate exhaust. _________________ A redline a day keeps the carbon away! |
Posted: Sun May 08, 2011 7:24 am Post subject: |
Find an empty parking lot with a brick wall or building or something and drive slowly next to it in varying circles at varying speeds and in a straight line.
Listen for the noise and you should be able to pinpoint exactly where it's coming from, and when it happens.
Could be ball joints, a wheel bearing like Paul said, tire dragging on the fender liner, something hitting the steering linkage, who knows. |
