91camaro_rs Member
Posted: Sun Apr 17, 2011 7:45 pm Post subject: brake lights/ hazard flasher fuse issue |
so whenever i go to use my hazards, it blows the Power Acc. fuse. it did it twice today, yes i did need my hazards twice, and when it blows the fuse my brake lights go out as well
anyone have any input on what could be going on? _________________
Posted: Sun Apr 17, 2011 7:49 pm Post subject: |
How'd you power your wbo2? _________________
91camaro_rs Member
Posted: Sun Apr 17, 2011 8:14 pm Post subject: |
i had to take the wideband out, but i powered it using the accessory wire off the ignition, i had this problem for about a week or so now, its happened like 4 times, and it happened before the wideband was put in _________________
91camaro_rs Member
Posted: Sun Apr 17, 2011 9:51 pm Post subject: |
no i havent, bulbs are still the same ones as when i got the car 3 years ago
would having dirty contacts on the brake lights cause them to blow the fuse when i turn on the hazards?
i didnt know they were connected _________________
Posted: Mon Apr 18, 2011 7:12 am Post subject: |
| That's a good question. I don't have a schematic in front of me but the light issues seem to be fixed by cleaning sockets and making sure the right bulbs are in there. |
Posted: Mon Apr 18, 2011 7:57 am Post subject: |
If it doesn't do it with just turn signals its related to the hazard wiring. Take out the fuse and trace the short to ground. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Mon Apr 18, 2011 11:12 am Post subject: |
do i trace it using resistance w/ ohmeter? _________________
Posted: Mon Apr 18, 2011 11:16 am Post subject: |
If you take a volt meter and put it on the load side, not the power in to the fuse..... and the other lead to ground.... you'll have continuity if there is a short. There should be some as the bulbs are grounded. So what you'd want to do, is start unplugging harnesses and or bulbs so isolate harnesses. _________________ A redline a day keeps the carbon away! |
