Rag joint replacement
PostPosted: Sun Apr 03, 2011 11:04 am    Post subject: Rag joint replacement Reply with quote
How does one replace the original, which appears to be riveted together? Granted, it's a bit easier with the engine out of the way as it is now, but still looks to be quite the job to separate the thing. Here's a shot of it looking toward the steering box.
Leejo2005
PostPosted: Sun Apr 03, 2011 1:15 pm    Post subject: Reply with quote
I'll take a look at mine when I get home. I don't remember how I did it but I did do it when I changed my steering box.
2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
1967 Satellite Sport 383
PostPosted: Sun Apr 03, 2011 1:31 pm    Post subject: Reply with quote
Remove steering shaft from car, drill rivets out and replace disc that comes with new bolts.
Have you thought about a ragjoint eliminator? Or even the astrovan ujoint mod? Dewey and I both have the rag joint eliminator and I've noticed no ill effects.
PostPosted: Sun Apr 03, 2011 3:03 pm    Post subject: Reply with quote
I think I'm going to go to the other end and pull the box off so I can either clean it up or replace it with a quick ratio box. The joint and shaft should come off pretty easy without the box on the car. I have given the eliminator some thought, the only issue I see is if the shaft isn't perfectly aligned with the box, there may be a binding point.
Hey Aaron, do you still have that quick ratio box available? I can pull mine off next weekend and make a trip to trade you.
bAd DaWg 85 Z28
PostPosted: Sun Apr 03, 2011 3:11 pm    Post subject: Reply with quote
I replaced the one on the truck with one i bought at napa. its been a couple of years back. but as far as i know they still sell them
If ya can't fixit F#ck IT!!!!!!.........
DaWg
85 Z28
65 Chevy sport truck
85 K20 4x4 truck
PostPosted: Sun Apr 03, 2011 3:21 pm    Post subject: Reply with quote
That's why I want to replace it. It's much more accessible with the motor out, it's a bit worn, and it's available at the parts store Cool
PostPosted: Sun Apr 03, 2011 6:59 pm    Post subject: Reply with quote
FWIW, I did this mod right after dew back in '07 and I think I've put ~60-70k on the car since then and I haven't had any issues. I do need to replace/rebuild the box and toss on a geared down PS pump but those are other issues.
