sub box specs
91camaro_rs
PostPosted: Mon Apr 04, 2011 9:20 pm    Post subject: sub box specs Reply with quote
does anyone have sub box dimensions for the trunk? i know you can buy boxes for like $150, but im sure i could just buy a sheet of MDF and do it myself for way less. i picked up two 12" MTX Thunder 6000's today for $50
PostPosted: Mon Apr 04, 2011 10:22 pm    Post subject: Reply with quote
Sign into TGO, then copy the PDF file in this post. It's about the best fit out there. You may have to modify it a little around the latch. Though my box has a bit of fiberglass, it is based on this design, but to remove the box, my pulldown has to come out first (box was built in the car).
http://www.thirdgen.org/techboard/posts/car-audio/306257-dimensions-well-sub-box/3165044-post62.html
Also, keep in mind the air space requirements of your woofers and adjust your dimensions accordingly.
PostPosted: Tue Apr 05, 2011 3:08 am    Post subject: Reply with quote
i cant look at that link but the demensions from the tech article on tgo did not work for me.
-Donald
