drag radial preferences
Goto page 1, 2, 3  Next
91camaro_rs
PostPosted: Sun Mar 27, 2011 2:26 pm    Post subject: drag radial preferences Reply with quote
ok so i got some extra cash and racing season is in a month, im gonna get some drag radials to put on my stock iroc wheels
so does anyone have a preference? i was thinkin about the Nitto NT555R's
PostPosted: Sun Mar 27, 2011 3:48 pm    Post subject: Reply with quote
I like the Mickey Thompson drag radials.
PostPosted: Sun Mar 27, 2011 6:14 pm    Post subject: Reply with quote
Don't the Nitto double up as a great corner carving tire, too?
PostPosted: Sun Mar 27, 2011 6:29 pm    Post subject: Reply with quote
Mickey Thompson.
izcain
9sec Club
PostPosted: Sun Mar 27, 2011 6:31 pm    Post subject: Reply with quote
Mickey Thompson if you want to hook!
9.17 @ 148
91camaro_rs
PostPosted: Mon Mar 28, 2011 4:33 pm    Post subject: Reply with quote
should i be looking at subframe connectors too if im looking to run drag radials at the track?
PostPosted: Mon Mar 28, 2011 4:43 pm    Post subject: Reply with quote
You should be looking at subframe connectors even if you're only looking to run your car to the track's parking lot. Wink
<-- From: The guy with no SFCs. (Yet)
PostPosted: Mon Mar 28, 2011 4:48 pm    Post subject: Reply with quote
Yup yup
izcain
9sec Club
PostPosted: Mon Mar 28, 2011 5:11 pm    Post subject: Reply with quote
I would have to agree! You will love the increased feeling of the car with a set on!
9.17 @ 148
PostPosted: Mon Mar 28, 2011 5:24 pm    Post subject: Reply with quote
SFCs had the most significant effect on the feel of the car than anything else, combined, that I've added to the car - including shocks, springs, sway bars.
91camaro_rs
PostPosted: Mon Mar 28, 2011 8:47 pm    Post subject: Reply with quote
i just dont want my frame twisting at all...
and any brand preference on those too? i looked on summit and all the prices are the same for most of the brands...BMR, UMI, and global west
anyone know of a place that has em cheaper than $200 or is that about what they are
PostPosted: Mon Mar 28, 2011 9:02 pm    Post subject: Reply with quote
Each have their pros and cons, I have the UMI connectors and like them pretty well. Remember, along with the price of the connectors, there is the added cost to have them welded in. Depending on the shop, it can be as much as the connectors for hourly rates.
BluFbdy
PostPosted: Mon Mar 28, 2011 10:06 pm    Post subject: Reply with quote
hmmm i feel like we've had this conversation at some point.... lol
I went with BMR's SFC009, definitely helps ALOT and most of the squeeks are gone from the flexing, Andrew @ LoCash welded them on for me for 80 bucks, they bolt on the outside of the LCA's, and get welded to them, then the fronts get welded up to the frame, apparently mines been beat to hell cuz we had to do some modding to get the drivers side on there right, like someone just beat it in with a hammer, or nailed a speed bump going way to fast lol
any way, they ran me like 200$ i believe, i got them from summit and after the welding i was just shy of 300, not bad for the pros of them, and you probly wont find them for under 200, thats about the going rate
PostPosted: Tue Mar 29, 2011 4:00 am    Post subject: Reply with quote
Buy a subframe connector from the same company you want the torque arm, if you plan to upgrade your torque arm eventually. Sometimes the relocated torque arms are integrated to the subframe connectors. Everything is easier if you already have the right subframe connectors.
For example, I have Kenny Brown subframe connectors (don't think they are made any longer). They are round tube. I've been looking at a BMR short arm drag suspension but it mounts to a square BMR subframe tube. Kind of hard to weld up to a round subframe like what I have. But my KB's are already welded in so they are NOT coming out.
BluFbdy
PostPosted: Tue Mar 29, 2011 9:33 am    Post subject: Reply with quote
Notch the torque arm to fit to round tube? Or just duct tape it that will work right? Laughing
91camaro_rs
PostPosted: Tue Mar 29, 2011 3:17 pm    Post subject: Reply with quote
so i had the camaro aligned today cause i havent done it since it was lowered Embarassed
anyway like 5 minutes after they get my car on the rack they call me back there, and they showed me where the steering box is attached to the frame the frame is actually cracked, and when they moved the steering wheel back and forth you could see it flexing...how do i go about fixing this?
izcain
9sec Club
PostPosted: Tue Mar 29, 2011 4:24 pm    Post subject: Reply with quote
time to bust out the mig and some reinforcing plates!
9.17 @ 148
91camaro_rs
PostPosted: Wed Mar 30, 2011 2:53 pm    Post subject: Reply with quote
called my buddy today, he is gonna fix it next week
PostPosted: Wed Mar 30, 2011 3:11 pm    Post subject: Reply with quote
That crack in the frame near steering box is what the steering brace (aka 'wonder bar') was designed to help prevent. If your bud can fix it for you might be a good idea to invest in one.
91camaro_rs
PostPosted: Wed Mar 30, 2011 4:02 pm    Post subject: Reply with quote
IIRC a wonder bar is only like $40 on summit, ill definatly get one of those,
http://www.summitracing.com/parts/GLS-TS-14/
i think this week is camaro upgrade week i worked way more than i thought so im bringin in bank, hopefully i can get this fixed up, get a wonder bar, radials, and possibly SFC's
Page 1 of 3
