Posted: Sun Mar 20, 2011 7:15 pm Post subject: |
Al Hasse wrote: | Out with the old....
Now I have 2 or 3 weeks to clean up the engine bay, maybe get some black paint in there, clean up accessory brackets, clean up the harness and replace lots of the corrugated loom.
And thanks Aaron for the help in pulling this thing out.
Yet another picture of the Mountain Man with an engine coming out of a 3rdgen! _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
turbo_jimi Member
Posted: Sun Mar 20, 2011 8:11 pm Post subject: |
After seeing those pics, I was inspired to start organizing my shed...found a bunch of stuff I forgot I even had. _________________
Posted: Sun Mar 20, 2011 8:44 pm Post subject: |
RSFreak wrote: | Yet another picture of the Mountain Man with an engine coming out of a 3rdgen! |
Whether you want your broke-d**k Chevy towed, or your piece of crap 305 removed, I'm the guy to do it.
I think this clutch has probably seen it's last burnout in front of the IHOP.
Posted: Sun Mar 20, 2011 8:50 pm Post subject: |
aaron_sK wrote: | I think this clutch has probably seen it's last burnout in front of the IHOP.
It wasn't slipping yet, but shifting was starting to get a little difficult. |
Posted: Sun Mar 20, 2011 9:04 pm Post subject: |
Hehe... Al that clutch and flywheel are so cooked their next gig should be with the blue-man group. |
Posted: Sun Mar 20, 2011 9:07 pm Post subject: |
Agreed |
Posted: Sun Mar 20, 2011 10:17 pm Post subject: |
aaron_sK wrote: | I think this clutch has probably seen it's last burnout in front of the IHOP. |
Wasn't that Denny's?!?! _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Mon Mar 21, 2011 5:29 am Post subject: |
The IHOP was at Cows or dyno or something, the Denny's was in Tacoma before the Gig Harbor car show.
I'm sure there's more I'm forgetting. Al has burned out in front of many many restaurants. |
Richster Magic Fingers
Posted: Tue Mar 22, 2011 10:06 pm Post subject: |
It's amazing how many hoses and wires...miles of the stuff are in these cars!
Nice progress! _________________
Posted: Wed Mar 23, 2011 6:37 pm Post subject: |
Richster wrote: | It's amazing how many hoses and wires...miles of the stuff are in these cars!
Nice progress! |
You got that right I just got some various sizes of corrugated tubing to replace the pieces that are all cracked and broken, and extend as necessary.
I just tried to clean up the transmission and accessory brackets. Transmission turned out OK, but inside the bell housing is still pretty gunked up, I left it alone.
Simple green does pretty good if you're able to use a scrub brush. I need something to spray on, let foam up and rinse off without much scrubbing. Any ideas?? Those brackets are pretty nasty.
My battery tray has some corrosion in it, but since it's just started, rust is only on the surface. I need to scrub that out, clean it up and paint it with the rest of the bay.
Next, before the new motor arrives, sensors and switches that will transfer over come off, as well as the valve covers (I haven't decided if I'll keep them yet) and water pump. |
Posted: Wed Mar 23, 2011 6:42 pm Post subject: |
Go to the dollar store and buy a bunch of oven cleaner. Works great. Also I think castrol superclean is alot stronger then simple green. |
Posted: Wed Mar 23, 2011 6:45 pm Post subject: |
Cool, thanks. I haven't thought of that. I found out that Super Clean works a little better as I had a little on the shelf in the garage. |
Posted: Wed Mar 23, 2011 7:04 pm Post subject: |
the CSC is what I use. Works, but still needs scrubbed.
For the battery tray, Ive used Permatex rust treatment as the can recommends. Its stopped it for 2-3 years now on my car. Even some spots that were more then surface rust. But if its starting to flake, its had. |
Posted: Wed Mar 23, 2011 7:08 pm Post subject: |
POR15 will kill the rust in the tray and be just about impervious. You would need very very little of it just to do that job though. |
SlackerTA Member
Posted: Wed Mar 23, 2011 8:12 pm Post subject: |
Oven cleaner is awesome stuff just watch out for the fumes. That stuffs nasty! _________________ '91 Firebird - LO3, 700R4, 2.73 gears
'85 Trans Am - SOLD
'95 Z28 - SOLD |
Posted: Thu Mar 24, 2011 7:09 pm Post subject: |
chevymad wrote: | Go to the dollar store and buy a bunch of oven cleaner. Works great. Also I think castrol superclean is alot stronger then simple green. |
Gasoline actually works okay with a bit of elbow grease, but at this point, oven cleaner is cheaper _________________
Posted: Thu Mar 24, 2011 9:09 pm Post subject: |
Oven cleaner does quite the job. All the cast aluminum brackets look like aluminum now, not perfect, but presentable. Power steering bracket, pump and box were the worst. I only got 2 cans, could have used more, but I think except for repairing some of the harness, the bay is ready for the new motor |
Posted: Thu Mar 24, 2011 9:13 pm Post subject: |
If you have a dollar store to buy from its a very cheap effective method. Learned it from the truck guys. They were using it for cleaning their frames and suspension. |
Posted: Wed Apr 06, 2011 5:45 pm Post subject: |
I received a piece today that will help the transmission survive at least a little longer. This will probably have to be replaced again when I upgrade to T-56, but I feel it's necessary to prolong the life of the T-5.
One transmission cross-member with torque arm relocation bracket
turbo_jimi Member
Posted: Thu Apr 07, 2011 7:45 am Post subject: |
Where did you get that? It looks cool! _________________
