My swap - begining to end
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
PostPosted: Sat Mar 19, 2011 5:03 pm    Post subject: My swap - begining to end Reply with quote
The 305 is coming out either tomorrow or next weekend. Today, I unbolted all the accessories, removed the ones that would come out - power steering pump is just move over. I disconnected most of the harness, only a couple of more connectors to go, the ground on the back of the passenger head was a $#@*!!. Headers are disconnected from the Y-pipe, but still attached to the block.
This is where I'm at now...
PostPosted: Sat Mar 19, 2011 7:52 pm    Post subject: Reply with quote
Cool...that's quite alot.
PostPosted: Sat Mar 19, 2011 9:21 pm    Post subject: Reply with quote
Good thing I have a new intake coming with the motor, this one probably isn't big enough anyhow. That thermostat bolt snapped off as I tried to loosen it.
I also had to go out and get a T-45 torx for the accessory brackets. I haven't seen torx head bolts used for accessory brackets before.
PostPosted: Sat Mar 19, 2011 10:24 pm    Post subject: Reply with quote
GM liked 'em in the 80's.
You get Mike's picker, or you need mine?
I might come up tomorrow, depending on what needs to be done here. I got the Monterey running today, so that's off my plate. Wink
What time you starting?
PostPosted: Sat Mar 19, 2011 11:13 pm    Post subject: Reply with quote
I have Mike's picker in the garage, I might need a stand though. Anytime is fine, I'll probobly get started mid to late morning. I still have to unhook some of the harness and unclip it from the block in places. Also separate the block from the tranny, if necessary.
PostPosted: Sat Mar 19, 2011 11:21 pm    Post subject: Reply with quote
Stand is full of motor right now. Wink
Pull the trans with the engine. Makes it easier with a stick IMHO. Auto you can prop up and leave in.
PostPosted: Sat Mar 19, 2011 11:29 pm    Post subject: Reply with quote
Then I may have to let the car down and roll it back a few feet for room, but I can do that after I get what need disconnected done. Do you have a leveler? I didn't see one with Mike's picker and I didn't think to ask.
nonsensekid20
PostPosted: Sat Mar 19, 2011 11:35 pm    Post subject: Reply with quote
Looks about where I was a few years ago. hahah. What are you putting in?
PostPosted: Sat Mar 19, 2011 11:39 pm    Post subject: Reply with quote
Never needed one bad enough to go buy one. Laughing
You aren't related to John, are you?
PostPosted: Sat Mar 19, 2011 11:40 pm    Post subject: Reply with quote
383 TBI with Vortec heads and intake. The builder hasn't decided on a cam just yet, but all pertinent info will be on a data sheet with the motor when delivered.
PostPosted: Sat Mar 19, 2011 11:43 pm    Post subject: Reply with quote
Looking good!
Look how far you've come since swapping the v6 out!
nonsensekid20
PostPosted: Sun Mar 20, 2011 12:06 am    Post subject: Reply with quote
Very nice! My uncle has a 383 roller in his 65 Nova. trick flow heads, air gap edelbrock intake. It's a sweet ride. I'm sure you'll be more than happy with yours.
Not that I know of.. Laughing
KatsCam
PostPosted: Sun Mar 20, 2011 9:34 am    Post subject: Reply with quote
I can't wait to hear and see that when it's done, Al. Good luck! Smile
PostPosted: Sun Mar 20, 2011 10:19 am    Post subject: Reply with quote
After the new one is in, it "should" look almost stock Cool
I just finished getting everything on the harness disconnected (I hope Laughing). All lines and hoses are disconnected/removed, so all I have to do is undo the mounts and pull.
PostPosted: Sun Mar 20, 2011 10:31 am    Post subject: Reply with quote
I had a water neck bolt snap off in my L03 intake back in the day too. What a PITA! What intake are you gonna run?
PostPosted: Sun Mar 20, 2011 10:43 am    Post subject: Reply with quote
Vortec, to match the heads. Motor is coming complete, oil pan to throttle body Cool
SlackerTA
PostPosted: Sun Mar 20, 2011 4:12 pm    Post subject: Reply with quote
I'm so jealous, Al! Very Happy
'91 Firebird - LO3, 700R4, 2.73 gears
'85 Trans Am - SOLD
'95 Z28 - SOLD
PostPosted: Sun Mar 20, 2011 4:18 pm    Post subject: Reply with quote
Out with the old....
Now I have 2 or 3 weeks to clean up the engine bay, maybe get some black paint in there, clean up accessory brackets, clean up the harness and replace lots of the corrugated loom.
And thanks Aaron for the help in pulling this thing out.
PostPosted: Sun Mar 20, 2011 5:13 pm    Post subject: Reply with quote
Did you guys get to any tear down of the old mill to find out what actually happened?
PostPosted: Sun Mar 20, 2011 5:19 pm    Post subject: Reply with quote
There was a little water in the oil when I drained it, but not a lot. We took the oil pan off while still on the picker. All the rod bearings seemed OK, no loose ones were evident. The engine definitely had a knock, though.
Page 1 of 10
