		| Author | Message |
		| RSFreak The other "John"
 1989  Chevrolet  Camaro RS
				|  Posted: Mon Mar 07, 2011 7:28 pm    Post subject: adjusting idle speed? |   |
				| The idle speed on my T/A drops to about 500 RPMs when in gear. In park or neutral it idles at around 750 - 850. It seems like its gonna die when the RPMs drop when the car comes to a stop. I'd like to have it idle around the same speed as when in park/neutral. What values do I need to change in the bin to accomplish this? I am using an '89 305 TPI auto trans bin with the $6E mask in Tunerpro. _________________
		| Back to top |  |
				|  Posted: Mon Mar 07, 2011 7:31 pm    Post subject: |   |
				| You need to re-set minimum air followed by a tps adjustment. No tuning needed for a stock motor. Should be around 600rpm in gear. _________________
		| Back to top |  |
				|  Posted: Mon Mar 07, 2011 7:42 pm    Post subject: |   |
				| With the LT1 cam it is still basically stock, right? _________________
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Mon Mar 07, 2011 8:09 pm    Post subject: |   |
				| What chip is this, John? Gabe and I upped the idle speeds in the BIN I e-mailed you. |  |
		| Back to top |  |
				|  Posted: Mon Mar 07, 2011 9:09 pm    Post subject: |   |
				| Thats with the most recent bin you sent me. I'll know better after driving to work if the tranny is performing better or not, but it still idles low in gear. _________________
		| Back to top |  |
				|  Posted: Mon Mar 07, 2011 9:16 pm    Post subject: |   |
				| aHH. Didn't know of the updated cam. _________________
		| Back to top |  |
				|  Posted: Mon Mar 07, 2011 9:47 pm    Post subject: |   |
				| The LT1 cam is only slightly more aggressive than the stock 305 TPI cam. Think that would make a difference? _________________
		| Back to top |  |
		| popballz Member
 1989  Pontiac  Firebird
				|  Posted: Mon Mar 07, 2011 9:48 pm    Post subject: |   |
				| mine does that after its warm, when its cold it runs great!
 so do we have the same problem or is yours just from upgrades?
 -Donald
		| Back to top |  |
				|  Posted: Mon Mar 07, 2011 9:54 pm    Post subject: |   |
				| I got kind of a Franken-'Bird going on here. Its got a '91 long block and TPI with an LT1 cam running an '89 tune. I'm running the '89 bin because the later TPI setup deletes the 9th injector which is needed for cold starts. '89 was the last year for the f-bodies with the MAF and '165 ecm. _________________
		| Back to top |  |
				|  Posted: Mon Mar 07, 2011 9:58 pm    Post subject: |   |
				| It makes considerably more power in an '87+ 305 than the stock cam, also has a wider lobe seperation angle.
 It's enough that the ECM isn't completely sure what to do with it.
		| Back to top |  |
				|  Posted: Mon Mar 07, 2011 10:04 pm    Post subject: |   |
				| I know I need to get some data logging equipment and get a tune dialed in. _________________
		| Back to top |  |
		| Alphius Peanut
 1984  Chevrolet  Camaro Z/28
				|  Posted: Mon Mar 07, 2011 10:58 pm    Post subject: |   |
				| Didn't we turn the idle up to 650 in gear on that chip Aaron? Maybe the IAC is sticking. Or minimum air isn't set right.
 I don't know a ton about the TPI computer, but shouldn't it target an idle speed and "just work"? Stock chip was set to do 550 in gear if I remember right.
		| Back to top |  |
				|  Posted: Mon Mar 07, 2011 11:15 pm    Post subject: |   |
				| There are two variables in the bin called IAC Target Speed Deadband for Park/Neutral and IAC Target Speed Deadband for Drive. The first is set to 50.00 RPM. The second is set to 12.50 RPM. Not sure if these are the values I'd need to change or not. _________________
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Tue Mar 08, 2011 7:09 am    Post subject: |   |
				|  	  | RSFreak wrote: |  	  | There are two variables in the bin called IAC Target Speed Deadband for Park/Neutral and IAC Target Speed Deadband for Drive. The first is set to 50.00 RPM. The second is set to 12.50 RPM. Not sure if these are the values I'd need to change or not. |
 Deadband is the amount of flexibility you give the chip before it starts to move the IAC. That's not what the problem is. You want idle speed vs. coolant temp.
  	  | Alphius wrote: |  	  | Didn't we turn the idle up to 650 in gear on that chip Aaron? Maybe the IAC is sticking. Or minimum air isn't set right. |
 Indeed. My guess would be misadjusted TPS like Paul mentioned, but it could be a lot of things. The chip should have raised it. Since it didn't we need to look for a mechanical issue.
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Tue Mar 08, 2011 8:41 am    Post subject: |   |
				|  	  | aaron_sK wrote: |  	  | My guess would be misadjusted TPS |
 Right, I didn't even think of that cause my MegaSquirt doesn't use the TPS as an idle input.
 If the voltage isn't low enough at 0% TPS it will never go to idle mode, right? It should be a pretty easy fix anyway. Can we datalog it? Do either of you guys have an ALDL cable? I can bring mine to dyno... I'll probably never use it again. That's if I can find it.
		| Back to top |  |
				|  Posted: Tue Mar 08, 2011 3:20 pm    Post subject: |   |
				| I don't have an ALDL cable yet. I noticed today that at idle in gear it idles very rough like it has a BIG cam, not like its misfiring, just very lopey.
 I wouldn't discount the IAC sticking. I'm sure its plenty dirty.
		| Back to top |  |
				|  Posted: Tue Mar 08, 2011 4:12 pm    Post subject: |   |
				| You guys understand what the minimum air adjustment does right? _________________
		| Back to top |  |
				|  Posted: Tue Mar 08, 2011 4:17 pm    Post subject: |   |
				| I'm gonna guess its the minimum amount of air the engine needs to idle?  _________________
		| Back to top |  |
				|  Posted: Tue Mar 08, 2011 5:56 pm    Post subject: |   |
				| Basically. It's giving the engine the most air it can, with minimal room for the IAC to close. Most aftermarket or tuned setups like your hot idle IAC counts to be at about 20 (out of 160) open in gear. So you open the throttle, the IAC counts drop because the ECM sees it doesn't need the IAC open as far, to achieve the desired idle.
 After you set this you must reset the TPS so all other functions are appropriate.
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Tue Mar 08, 2011 7:36 pm    Post subject: |   |
				| John, if I find my ALDL cable you might be able to persuade me to part with it if it's for a good cause.  _________________
		| Back to top |  |
