redlava Member
Posted: Tue Mar 22, 2011 8:49 pm Post subject: Caster/Camber plate questions |
I am looking at the UMI/J&M caster and camber plates for the strut towers. What do these offer over the stock replacements, besides the extra range of motion. If I did not need the extra range of motion would I gain the same performance by getting the stock replacements? Do the stock mounts wear? Are both the after market and stock replacements, both have a solid bearing?
Thanks |
Posted: Tue Mar 22, 2011 9:46 pm Post subject: |
| The biggest benefit is the bearing, the stock replacements have a bushing that does wear and also flexes. The housings are probably a little better, but I don't know how much flex is induced in the housing, since the rubber and other stuff will move first. |
redlava Member
Posted: Wed Mar 23, 2011 4:21 pm Post subject: |
| yes, I was refering to those 91rs. Is it possible to have a solid bearing/mount pressed into the stock housing? |
Posted: Wed Mar 23, 2011 4:39 pm Post subject: |
Stock housing is rubber. _________________ A redline a day keeps the carbon away! |
Posted: Wed Mar 23, 2011 6:57 pm Post subject: |
I saw one kit a while back where you had to drill out the weld-rivits in the stock, and put an insert in the stock. Then bolt or weld it it back together.
Id just buy all new ones honestly. Thats what I did.
Most will buy these for the handling improvement, but I have to say I noticed better braking then handling. Either way, they are lightages better then stocks!! |
