Boring a cylinder
nonsensekid20
PostPosted: Fri Feb 11, 2011 4:14 pm    Post subject: Boring a cylinder Reply with quote
How much material can be taken off when boring a cylinder? FYI this is on my 2-stroke YZ250
PostPosted: Fri Feb 11, 2011 4:39 pm    Post subject: Reply with quote
Depends on the engine specifically.
You bore the engine to the piston size.
If you "bore" and engine, you need oversized pistons.
If you "hone" an engine, and the bore diameter is still within specifications, you can reuse the old piston/stock piston.
Though it sounds like your piston is junk anyway.
nonsensekid20
PostPosted: Fri Feb 11, 2011 4:43 pm    Post subject: Reply with quote
This goes back to the other post.
The cylinder is all messed up. So I need to bore it out. YZ250.
PostPosted: Fri Feb 11, 2011 6:06 pm    Post subject: Reply with quote
Means you take it to the machine shop. And talk it over with them how indepth you want to/need to go to rebuild the motor.
nonsensekid20
PostPosted: Fri Feb 11, 2011 6:19 pm    Post subject: Reply with quote
I know that. I'm wondering how much material they can take off.
PostPosted: Fri Feb 11, 2011 6:21 pm    Post subject: Reply with quote
Thats what you take it to the machine shop for.
nonsensekid20
PostPosted: Fri Feb 11, 2011 7:59 pm    Post subject: Reply with quote
Is there a maximum amount?
PostPosted: Fri Feb 11, 2011 8:06 pm    Post subject: Reply with quote
It's different for every motor, the damage will determine how much you have to bore it. Take it to the machine shop, they will determine how far they have to machine it, and will tell you if there is enough material left in the sleeve. None of us can tell you that, no matter how many different ways you try to word it.
The shop will tell you one of three possible outcomes.
1) They can bore it, and how much they need to bore it, so you can order the correct piston(s)
2) It is too damaged, and it needs a new sleeve
3) The motor is done for, look for a new motor, or a new bike.
nonsensekid20
PostPosted: Fri Feb 11, 2011 8:19 pm    Post subject: Reply with quote
Alright fair enough. It's been resleeved once. Hopefully I don't have to do it again. The cuts didn't seem that deep. That's why I wanted to know how much they could take off so I could measure it and not waste my time goin into the machine shop if I didn't have to.
PostPosted: Sat Feb 12, 2011 1:29 am    Post subject: Reply with quote
They might tell you the "cuts" are normal.
Piston rings score the cylinders in nature. How much is okay.... is subjective.
PostPosted: Sat Feb 12, 2011 6:01 pm    Post subject: Reply with quote
I would also check to see if over bore pistons are available for your engine and what sizes.
nonsensekid20
PostPosted: Sat Feb 12, 2011 7:27 pm    Post subject: Reply with quote
Cylinder
Piston
Cylinder head
PostPosted: Sat Feb 12, 2011 10:08 pm    Post subject: Reply with quote
thats really bad might need a new head. take a pic of the piston ring grove and include the ring pin. rings on 2 stroke pistons have to be stationary. looked like you broke the pin and the ring rotated and the end gap caught the intake or exhaust port.
