Posted: Sat Jan 29, 2011 10:55 pm Post subject: Holley Secondary |
Does anyone know how you adjust the secondaries on a manual secondary 4150? Mine isn't opening up all the way. I have no adjustment on opening and it appears that the lever is too long or that the hole has been hogged out from use on the secondary arm.
You can see it on the left side of this picture. Its the shiney inch long lever that links the primary and secondary.
 _________________ E30
Posted: Sun Jan 30, 2011 12:44 pm Post subject: |
I know very little about carbs, but on the Quadrajet there is a "stop" that can be bent down or cut off to allow the secondaries to open fully. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Jan 30, 2011 8:49 pm Post subject: |
What is this car-brew-a-tor thing you speak of?
Sorry I don't know diddly about carbs. _________________
Posted: Mon Jan 31, 2011 9:06 am Post subject: |
| I'm beginning to think no one knows carburetors any more. I will stop asking questions about them. |
Posted: Mon Jan 31, 2011 12:46 pm Post subject: |
Bend the rod to get the opening you want. _________________ A redline a day keeps the carbon away! |
RK82 Member
1982 Pontiac Trans Am
Posted: Tue Feb 01, 2011 4:35 pm Post subject: Re: Holley Secondary |
| blue89 wrote: | the lever is too long or that the hole has been hogged out
Bend the rod. _________________ A redline a day keeps the carbon away! |
Posted: Tue Feb 01, 2011 5:45 pm Post subject: |
| blue89 wrote: | | Bending the rod changes the timing on when the secondaries open. I really just need some fuel injectors so I can multi port this bad boy. |
Now that'd be cool. What size injectors do you need? _________________
Posted: Tue Feb 01, 2011 7:12 pm Post subject: |
| I need a set of 21 lb hour or so. Gotta support 400 HP. |
Posted: Tue Feb 01, 2011 8:21 pm Post subject: |
| blue89 wrote: | | I need a set of 21 lb hour or so. Gotta support 400 HP. |
I've got six brand new GM ones from a later 3.8 motor if you want them? (a, I don't know how big they are. b, yes I know you'll still have to get 2 more but this is a good start, right?!)
Are you coming to dyno? You're closer now, right? |
Posted: Tue Feb 01, 2011 8:56 pm Post subject: |
Too bad I tossed my two sets of LM7 injectors or I'd give em to ya free.
Lotsa things get tossed when this guy moves...  _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Feb 01, 2011 9:56 pm Post subject: |
Whaaaaaaaat? Should've just given back to me.  |
Posted: Tue Feb 01, 2011 10:02 pm Post subject: |
I have a few misc sets of injectors too but not a complete matching set of 8. I should just go get a set. I think its the only piece missing from my EFI setup. I'm a lot closer to the CCC hub now, no excuse to come out. All I need now is a trailer to get the car there.
And I just discovered I have a 750 throttle plate on a 650 main body. But at least I got the casting flash removed, throttle shaft slimmed, venturies cleaned, choke horn removed, and it's ready for DYNO!  |
Posted: Tue Feb 01, 2011 10:04 pm Post subject: |
| blue89 wrote: | it's ready for DYNO!  |
Posted: Tue Feb 01, 2011 10:06 pm Post subject: |
Posted: Tue Feb 01, 2011 10:07 pm Post subject: |
| iansane wrote: | Whaaaaaaaat? Should've just given back to me.  |
Sorry man, I was tossing things out left and right. I had a day and a half to go through my stuff and load it into the U-Haul. I paid you good money for those anyway. They were mine to toss...  _________________ 84 Camaro Z28 - LS1/T56
turbo_jimi Member
Posted: Wed Feb 02, 2011 6:19 pm Post subject: |
| blue89 wrote: | | I'm beginning to think no one knows carburetors any more. I will stop asking questions about them. |
aaron is familiar with carbs...even helped me with my edelbrock.  _________________
Posted: Wed Feb 02, 2011 7:29 pm Post subject: |
Or you could buy a whole new baseplate.. or even billet base plate. Nice thing with a holley is there are alot of parts available.
I havent said anything on this thread either because I havent had a double pumper since high school. Every holley i've had since has been a vac secondary. The few times I've worked on them, i've figured things out by looking at them, but just dont remember well enough to tell someone else how. I would probably try as Paul said though and just bend the link. |
