nonsensekid20 Member
Posted: Fri Jan 28, 2011 7:51 pm Post subject: 9 Bolt Borg Warner |
K so now the guy isn't selling the one with 3.23 gears. He's selling a different one with 2.77 gears. Still posi. And still disc brakes. Selling for $300 instead of $400 for the 3.23.
Good deal? |
Posted: Fri Jan 28, 2011 7:53 pm Post subject: |
For a land speed car.  |
Posted: Fri Jan 28, 2011 7:56 pm Post subject: |
| Well what's the real difference between them? Enough to notice? |
Posted: Fri Jan 28, 2011 8:20 pm Post subject: |
Yes. You are going in the way wrong direction.
Had that ratio in my S10 with Camaro wheels and tires, and the very low-geared S10 version of the T5, and it was garbage. Of course that was with a veesix, but still.  |
Posted: Fri Jan 28, 2011 8:37 pm Post subject: |
Idk if he still has the 3.23 for sale. If he does I'll buy that.
But the 2.77's.. shouldn't bother? |
IROCDave Member
Posted: Fri Jan 28, 2011 10:15 pm Post subject: |
| Dont other unless you plan to install a twin turbo charged 500+ big block. |
Posted: Sat Jan 29, 2011 4:19 pm Post subject: |
Way too deep a gear.
Unless you plan to go to Bonneville... _________________ A redline a day keeps the carbon away! |
bAd DaWg 85 Z28 Member
Joined: 14 Jan 2004 Posts: 157 Location: Taking up space
Posted: Sat Jan 29, 2011 5:36 pm Post subject: |
Hmm ... 2.77 freeway flyers 3.23 or 3.42 would work better for your setup $300.00 is a good deal......... _________________ If ya can't fixit F#ck IT!!!!!!.........
DaWg
85 Z28
65 Chevy sport truck
85 K20 4x4 truck |
Posted: Sat Jan 29, 2011 6:43 pm Post subject: |
| 2.77's sound good to me. Maybe then I can drive on the freeway. |
BigDaddyVu 12sec Club
Posted: Sat Jan 29, 2011 7:27 pm Post subject: |
that be perfect for my turbo car _________________
Posted: Sat Jan 29, 2011 10:53 pm Post subject: |
| I'll put you in touch with the guy if you want to buy it. |
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Sun Jan 30, 2011 5:18 pm Post subject: |
Its a BW with posi and disks.
Who cares what the ratio is, unless your a dragster, lets run em at every red light, give me tickets type dude  _________________
Posted: Sun Jan 30, 2011 8:33 pm Post subject: |
Wear out bearings with too low a first gear final drive. _________________ A redline a day keeps the carbon away! |
Posted: Sun Jan 30, 2011 8:37 pm Post subject: |
| Twilightoptics wrote: | | Wear out bearings with too low a first gear final drive. |
Man, nuts to the bearings, you need to accelerate fast. It's the American way!
Posted: Tue Feb 01, 2011 10:20 am Post subject: |
Car takes off plenty fast.
I'm gonna just save up the extra 100 and buy the one he has with 3.27 gears. 2.77 if you want to change out the gears you have to change out the carrier too. Cause it's a 2 series and not compatible with the 3 series. (obviously) |
Posted: Tue Feb 01, 2011 11:05 am Post subject: |
| It doesn't really matter whether it is a 2 or 3 series. The main thing is to avoid having to spend money on new gears in the future. Choose the gears now that will best suit your wants. Besides, factory GM gears are very strong and quiet. Aftermarket gears just aren't as good in general. |
Posted: Tue Feb 01, 2011 7:31 pm Post subject: |
| QwkTrip wrote: | | It doesn't really matter whether it is a 2 or 3 series. |
The 2 series niner is a b@$tard child, though. Only the 2.77 uses it.
http://www.9bolt.com/whatcarrier.html
Make the guy an offer on the 3.27. He's asking a bit much for it. |
Posted: Tue Feb 01, 2011 8:55 pm Post subject: |
| How much you think it's worth? |
Posted: Tue Feb 01, 2011 9:08 pm Post subject: |
| Well hang on, this rear end does have disc brakes and proportioning valve with it. Does the one Schultzy has have discs? |
