9 Bolt Borg Warner
nonsensekid20
PostPosted: Fri Jan 28, 2011 7:51 pm    Post subject: 9 Bolt Borg Warner Reply with quote
K so now the guy isn't selling the one with 3.23 gears. He's selling a different one with 2.77 gears. Still posi. And still disc brakes. Selling for $300 instead of $400 for the 3.23.
Good deal?
PostPosted: Fri Jan 28, 2011 7:53 pm    Post subject: Reply with quote
For a land speed car. Wink
nonsensekid20
PostPosted: Fri Jan 28, 2011 7:56 pm    Post subject: Reply with quote
Well what's the real difference between them? Enough to notice?
PostPosted: Fri Jan 28, 2011 8:20 pm    Post subject: Reply with quote
Yes. You are going in the way wrong direction.
Had that ratio in my S10 with Camaro wheels and tires, and the very low-geared S10 version of the T5, and it was garbage. Of course that was with a veesix, but still. Rolling Eyes
nonsensekid20
PostPosted: Fri Jan 28, 2011 8:37 pm    Post subject: Reply with quote
Idk if he still has the 3.23 for sale. If he does I'll buy that.
But the 2.77's.. shouldn't bother?
IROCDave
PostPosted: Fri Jan 28, 2011 10:15 pm    Post subject: Reply with quote
Dont other unless you plan to install a twin turbo charged 500+ big block.
PostPosted: Sat Jan 29, 2011 4:19 pm    Post subject: Reply with quote
Way too deep a gear.
Unless you plan to go to Bonneville...
bAd DaWg 85 Z28
PostPosted: Sat Jan 29, 2011 5:36 pm    Post subject: Reply with quote
Hmm ... 2.77 freeway flyers Pokey pokey 3.23 or 3.42 would work better for your setup $300.00 is a good deal.........
If ya can't fixit F#ck IT!!!!!!.........
DaWg
85 Z28
65 Chevy sport truck
85 K20 4x4 truck
PostPosted: Sat Jan 29, 2011 6:43 pm    Post subject: Reply with quote
2.77's sound good to me. Maybe then I can drive on the freeway.
PostPosted: Sat Jan 29, 2011 7:27 pm    Post subject: Reply with quote
that be perfect for my turbo car
nonsensekid20
PostPosted: Sat Jan 29, 2011 10:53 pm    Post subject: Reply with quote
I'll put you in touch with the guy if you want to buy it.
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Sun Jan 30, 2011 5:18 pm    Post subject: Reply with quote
Its a BW with posi and disks.
Who cares what the ratio is, unless your a dragster, lets run em at every red light, give me tickets type dude Very Happy
1985 Trans Am Recaro Option (AS5)
67,000 miles 5.0 TPI Hi Flow MAF
TPI Airfoil w/Bypass Flowmaster WS6 (.92g)
3:27 Borg Warner Posi K&N Filtration
PostPosted: Sun Jan 30, 2011 8:33 pm    Post subject: Reply with quote
Wear out bearings with too low a first gear final drive.
PostPosted: Sun Jan 30, 2011 8:37 pm    Post subject: Reply with quote
Man, nuts to the bearings, you need to accelerate fast. It's the American way!
Razz
nonsensekid20
PostPosted: Tue Feb 01, 2011 10:20 am    Post subject: Reply with quote
Car takes off plenty fast. Laughing
I'm gonna just save up the extra 100 and buy the one he has with 3.27 gears. 2.77 if you want to change out the gears you have to change out the carrier too. Cause it's a 2 series and not compatible with the 3 series. (obviously)
PostPosted: Tue Feb 01, 2011 11:05 am    Post subject: Reply with quote
It doesn't really matter whether it is a 2 or 3 series. The main thing is to avoid having to spend money on new gears in the future. Choose the gears now that will best suit your wants. Besides, factory GM gears are very strong and quiet. Aftermarket gears just aren't as good in general.
PostPosted: Tue Feb 01, 2011 7:31 pm    Post subject: Reply with quote
The 2 series niner is a b@$tard child, though. Only the 2.77 uses it.
http://www.9bolt.com/whatcarrier.html
Make the guy an offer on the 3.27. He's asking a bit much for it.
nonsensekid20
PostPosted: Tue Feb 01, 2011 8:55 pm    Post subject: Reply with quote
How much you think it's worth?
PostPosted: Tue Feb 01, 2011 9:01 pm    Post subject: Reply with quote
http://cascadecrew.org/phpBB2/viewtopic.php?t=7523
That one's going in my car though. Sorry. Laughing
nonsensekid20
PostPosted: Tue Feb 01, 2011 9:08 pm    Post subject: Reply with quote
Well hang on, this rear end does have disc brakes and proportioning valve with it. Does the one Schultzy has have discs?
