91camaro_rs Member
Posted: Fri Jan 21, 2011 2:20 pm Post subject: Throttle Position sensor |
im pretty sure mine is toast, its reading backward, when u give it gas the voltage and % goes down instead of up
i also broke a screw in the throttle body taking it off....sweet
so i need a TPS, and i dont really wanna buy a new one _________________
Darbbackwords New Member
Joined: 12 Mar 2010 Posts: 19 Location: Seattle/Whidbey
Posted: Fri Jan 21, 2011 3:00 pm Post subject: |
| Are you sure you are reading the correct pins? if you are measuring between the voltage source and signal instead of ground and signal you will get what you describe. |
MrMike98 Member
Posted: Fri Jan 21, 2011 3:52 pm Post subject: |
TPS is just a varible resistor, if it is varing it is working..
does the volts and % go down and then back up?
if ur reading this AT the tps ur just on the wrong wires. thers are 3 wires::grnd , +5volt, varible out.
sounds like tps is ok.. |
Posted: Fri Jan 21, 2011 4:58 pm Post subject: |
| He's datalogging, guys. He's seeing what the ECM sees, which is a high resistance spot at the bottom end of the sensor. |
