Water temp gauge
nonsensekid20
PostPosted: Mon Dec 13, 2010 11:53 am    Post subject: Water temp gauge Reply with quote
So the gauges work. Except the water temp. It worked for a second; Went up to 150 and stuck. Tapped on the gauge and it went back down. Now it doesnt work.
Is this the gauge or could it be the sending unit?
chevysquid
PostPosted: Mon Dec 13, 2010 12:34 pm    Post subject: Reply with quote
Sounds like the gauge to me if you tapped on it and then it went back down.
1986 IROC Z-28
PostPosted: Mon Dec 13, 2010 8:32 pm    Post subject: Reply with quote
I have seen several stocker temp gauges just fluke out. Junkyard part, or fleaBay.
nonsensekid20
PostPosted: Mon Dec 13, 2010 8:49 pm    Post subject: Reply with quote
It was a brand new outta the box Cobalt gauge from Autometer.
PostPosted: Mon Dec 13, 2010 8:51 pm    Post subject: Reply with quote
Aha. Check for proper wiring. If it is DOA, call Autometer. They are pretty good about replacements in my experience.
nonsensekid20
PostPosted: Mon Dec 13, 2010 8:55 pm    Post subject: Reply with quote
I ordered it from Summit. I should still send it back to Summit right?
And could it have been the sending unit that went out?
PostPosted: Mon Dec 13, 2010 8:57 pm    Post subject: Reply with quote
If the sending unit went out, you need to send it back anyhow, seeing as the sending unit is part of the kit you bought. Razz
I'm still betting on the wiring being crapped up.
PostPosted: Tue Dec 14, 2010 12:36 pm    Post subject: Reply with quote
I'm with stupid Wiring or gauge.
nonsensekid20
PostPosted: Thu Dec 16, 2010 11:38 am    Post subject: Reply with quote
Well I thought it might be the sending unit if it read the temp then stuck there. idk. Maybe it caused something in the gauge. Sent a message to Autometer. And Summit. Get 2 answers. lol
PostPosted: Thu Dec 16, 2010 2:11 pm    Post subject: Reply with quote
Pull the gauge out and check your wiring dude.
The sending unit is a resistance based sensor. So any resistance you caused with your wiring will cause problems.
