Posted: Fri Nov 12, 2010 10:22 am Post subject: Need help finding a wrecking yard for Suzuki/metros |
Need a trans for a 2000 Suzuki Swift 5spd.
Called everyone I can think of.
Who might have one?! _________________ A redline a day keeps the carbon away! |
Posted: Fri Nov 12, 2010 12:54 pm Post subject: |
| Same as a metro? I dont have, but i'll ask around. |
Posted: Fri Nov 12, 2010 1:27 pm Post subject: |
Should be. 1.3L 4cyl. _________________ A redline a day keeps the carbon away! |
Posted: Fri Nov 12, 2010 2:03 pm Post subject: |
Tried Foreign Engines, they don't have one.
So far I've found Transmission Xchange in Portland wants $940 for a reman.
B&R has one in Portland with 209,000miles for $750!
Pasco, Wa has one for $550 not sure on milage yet. Waiting for a call back.
Really don't wanna try and rebuild this. I don't know where to get parts up here. _________________ A redline a day keeps the carbon away! |
Posted: Fri Nov 12, 2010 2:19 pm Post subject: |
There were a couple of rebuild kits on ebay.. $170 or so. I find lots of automatics for it. There is one listing on portland criags.. someones selling alot of parts for one.. including a clutch. But no listing for the engine/trans.. maybe you oughta call anyway. There was one complete car for $750.. but says it has tranny noise!! LOL
If it needs a hardpart.. man.. I bet you'd be screwed. Is this Kayla's? I can't remember who had the swift now.. Anyway. If I find anything else.. i'll post up. |
Posted: Fri Nov 12, 2010 7:05 pm Post subject: |
Found a brass/bearing/seal/synchro kit for $150 locally. I'll rip it out tomorrow and see what it needs. Guy I talked to said at 100k bearings starting to go.
If she's lucky it just needs soft parts. Guy said he still gets hard parts at the dealer ?! _________________ A redline a day keeps the carbon away! |
Posted: Sat Nov 13, 2010 12:13 pm Post subject: |
If the dealer carries things for a 10 year old car thats awesome LOL.. Doubtful isnt is?  |
Posted: Sat Nov 13, 2010 4:27 pm Post subject: |
It is Suzuki so who knows.
Either way, it was just one of the rear mainshaft bearings. Totally. Missing like 4 balls and the cage is all fubared. NO other damage. Can't believe it. Rebuild kit should be in sometime in the middle of the week.
155k on the clutch and it still has considerable life left. Replacing anyways.
Ended up spending most of the day on the wiring! _________________ A redline a day keeps the carbon away! |
Posted: Sat Nov 13, 2010 8:09 pm Post subject: |
| So she knows how to use a clutch sounds like! You still going through the whole trans then? |
Posted: Sun Nov 14, 2010 7:37 pm Post subject: |
Yeah. To get to that bearing it had to come apart. Bearings on the diff are a little sketchy too. Might as well do it all while it's apart. Same thing with the clutch, cause I don't wanna pull it back apart later lol. _________________ A redline a day keeps the carbon away! |
