		corey davidson Member
   1986  Chevrolet  Camaro
				 Posted: Thu Oct 21, 2010 3:59 pm    Post subject: New project |
				So you all no I got a 86 blazer and the trans went out and now the engine is going. So, now its time for a swap 350 with 350 turbo transmission. Just wanna know if anyone in the crew has done this or knows of someone? I know some of you have blazers. _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 4:10 pm    Post subject:  |
				IIRC Paul used the 305 out of his first camaro to swap into an S-10.
Get the Jagsthatrun book, they have detailed instructions on what you'll need to do for the swap. _________________
				 Posted: Thu Oct 21, 2010 4:32 pm    Post subject:  |
				Ok thanks I joined a  group for s body trucks but half of them are like duh. I kinda know what I need but want this to be done right. Sence we all no i beat the crap out of my cars. _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 5:01 pm    Post subject:  |
				What transfer case are you gonna run?
What are you planning on doing to keep the smallblock from raping the little half-ton axles? |
				 Posted: Thu Oct 21, 2010 5:05 pm    Post subject:  |
				well I'm gonna us a 350 turbo off of a 350. I'm have to keep my foot out of it till I an find a good axle for it any ideas on the axle. _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 5:09 pm    Post subject:  |
				A TH350 is a transmission, not a transfer case. Might want to make a note of that for future reference.
Your Blazer is an IFS if I am not mistaken, so you cannot just "find" an axle for it.
My sincere advice is to find a later-model 2.8L, or a Camaro longblock, and a 4x4 60* bell 700R4. You will have invested much less money, for a much more reliable truck.
BTW, I agree about guys on S-series forums. Hell, most guys on truck forums are morons period.
				 Posted: Thu Oct 21, 2010 5:17 pm    Post subject:  |
				I'm not putting the 4wd in it that's all ready out. They are pretty moronic I asked something about dropping my truck a couple inches and a couple of them said "I cant drop it because  you can't drop leaf springs." _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 9:32 pm    Post subject:  |
				does any one no if I can us the 2.8 mounts I'v heard yes and I'v heard no? _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 9:38 pm    Post subject:  |
				 	  | corey davidson wrote: | 	 		  | I'm not putting the 4wd in it that's all ready out. |
Define "out". Presumably the IFS is still in the vehicle, and it will cause you a headache trying to fit the oil pan. They make pans specific to the 4x4 SBC swap, but they are spendy. |
				 Posted: Thu Oct 21, 2010 10:28 pm    Post subject:  |
				By out i mean the front axle is still set u. for it. But, I'm not putting it back in so I need to buy the oil pan   _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 10:33 pm    Post subject:  |
				If you're going to be throwing that much money into it, you may as well find a 4x4 TH350 or 400 mated to a 203, 205 (preferably) or a 208, and just go for it.
That said, I still think the best bet is to retain the 60* setup. For the price of a pullout engine/trans and a front driveshaft, you'd be rolling a working 4x4 in time for the weather, and getting decent mileage. |
				 Posted: Thu Oct 21, 2010 11:04 pm    Post subject:  |
				True idk what im do now i was hoping that just doing a engine transfer would save me cash me and Greg were gonna do it. But, the engine is 300 to rebuild the carb its gonna be 75  200$ for the trans and than 100 for the distributor than plus what ever it will cast for everything else.   I found a nice s10 for 800 that runs perfect just runs a little rich.
   Maby you guys would no whats rong right now with the truck well now wen i start it it jsut dies in less i put my foot in to it than if it stays running ti runs hard like its not getting gas. Than when put in gear it dies or runs hard? any ideas ill just wait on the swap i think _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 11:14 pm    Post subject:  |
				Gotta check for oil pressure on the old 60* motors. Gotta do it accurately too, not just with the idiot light. Watch the vid in my photobucket that I took of the 2.8 we pulled out of my buddies Camaro if you don't believe me.
I forget if '86 was the 2brl or the TBI. If it's a carb there's still a mech pump on the block. If it's TBI they run intank. Regardless, you can check for lack of fuel with starting fluid.
Need to confirm consistent spark on all cylinders, and check timing as well. |
				 Posted: Thu Oct 21, 2010 11:17 pm    Post subject:  |
				Its a remand that is a tbi. how dare you think i even have an idiot light my dash stuff don't even work    _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 11:19 pm    Post subject:  |
				greg thinks it may be the torque converter and my moms boyfriend thinks fuel pump. i could take a video tomorrow and show you what it does _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 11:22 pm    Post subject:  |
				 	  | corey davidson wrote: | 	 		  | remand |
Noun
The act of sending an accused person back into custody whilst awaiting trial.
The act of an appellate court sending a matter back to a lower court for review or disposal.
TBI should have a schrader valve on it if I'm not mistaken. Check for oil and fuel pressure first. |
				 Posted: Thu Oct 21, 2010 11:34 pm    Post subject:  |
				"yeah its a replacement sorry"  and sounds good ill try is there any other transmission that will bolt to the 2.8 besides the 700r4 _________________ real men are covered in oil and grease |
				 Posted: Thu Oct 21, 2010 11:40 pm    Post subject:  |
				cool have to look in to that thanks for your help Aaron. Ill post a video if i can get it started tomorrow so i can show you guys what its doing. _________________ real men are covered in oil and grease |
				 Posted: Fri Oct 22, 2010 11:04 am    Post subject:  |
				http://www.youtube.com/watch?v=bn8n2Qv-J3k
here is the video i took today at about :40 is wen it starts to start _________________ real men are covered in oil and grease |
