Posted: Fri Sep 17, 2010 5:05 pm Post subject: Zee are won |
So we've had several of these at my dealership but I've never really taken any pictures of them so I decided to snap a few. You brake lovers will love this one:
Damn those are huge! These are the same brakes that the Ferrari Enzo uses on the front. Oh wait. Yeah that's right. Chevy put those on the REAR of the ZR1...
Now this is what they use up front...
To put these into perspective those rotors have the same diameter as the WHEELS on stocks IROC's.
And yes, I did get to take it for a test drive
 _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Sep 17, 2010 5:05 pm Post subject: |
| I think I need to upgrade my brakes. |
Posted: Fri Sep 17, 2010 5:11 pm Post subject: |
Jesus christ! When that pic first came up, I momentarily thought you had taken a picture of a clutch disk or something.  |
You best have deeeep pockets. Last I checked, these brakes cost no less than $12,000. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Sep 17, 2010 9:23 pm Post subject: |
| Dewey316 wrote: | | I think I need to upgrade my brakes. |
Meeee too... I wonder if the ctsv uses similar non ceramic rotors?
| DBL_TKE wrote: | | You best have deeeep pockets. Last I checked, these brakes cost no less than $12,000. |
Retail, yes. However, actual cost (unless it's changed in a few months) is really only a few hundred dollars per caliper and I think it was $1200 per rotor? Not cheap by any stretch of the imagination, but not 12k.  _________________
Posted: Fri Sep 17, 2010 10:16 pm Post subject: |
| iansane wrote: | | Dewey316 wrote: | | I think I need to upgrade my brakes. |
Retail, yes. However, actual cost (unless it's changed in a few months) is really only a few hundred dollars per caliper and I think it was $1200 per rotor? Not cheap by any stretch of the imagination, but not 12k.  |
12k is what the dealer charges as an "option" lol _________________ A redline a day keeps the carbon away! |
Posted: Fri Sep 17, 2010 10:39 pm Post subject: |
| Twilightoptics wrote: | | 12k is what the dealer charges as an "option" lol |
Ooooooh. Is that also what they charge for the z07 package or whatever on the Z06? (ZR1 brakes/suspension). I guess I'm out of the loop on what cars are going for nowadays.  |
Posted: Sat Sep 18, 2010 4:49 am Post subject: |
Meeee too... I wonder if the ctsv uses similar non ceramic rotors? |
hahah, I want the ceramic setup. If it is good enough for Ferrari, it is a good start for my car. hahhaha |
IROC-stangs Member
Posted: Sat Sep 18, 2010 5:25 am Post subject: |
MMMM YUMMY! those things are amazing, same with those rims, tires, carbon fiber and of course THE CAR! I would seriouly love to atleast ride in an zr1  |
